Rear Hatch courtesy light switch location???
Chugiak, Alaska
I'm try to diagnose which door switch is bad in my 1993 FZJ80, the door open light is on and the interior lights don't work. I cannot find the rear hatch door courtesy switch. I ordered a switch from the local dealer and they printed a diagram that shows it is by the 3rd brake light but I can't find it. Anyone know where it is? Thanks
I hate to sound like a DA, but did you check to make sure that the one of the two switches on the headliner wasn't accidentally switched on first?
EDIT: Nevermind - I can't read the first time around.
I really do wish it was that easy. This rig was in a wreck and the drivers side doors were off for a while as well as the rear hatch so I assume it is one of those switches.
Anyone with the factory service manual that could look it up for me?
In my 96 I think the switch is built into the latch mechanism on the upper half of the tailgate. I can't find it anywhere else. Try using a screwdriver to simulate the latch on the tailgate and see if you can get it to work.
I too believe the switch is integrated with the latch mechanism. I tapped into the swtich wiring to allow me to turn the rear light on/off from a more convienent switch. What I found was that the light turns on/off via the door latch and you can push the latch up with a screw driver to get the light to turn off.
You can access the wiring and switch, by removing the inner plastic panel just under the window. There's two screws that holds the interior latch handle, then the rest of the panel just pops off.
If the hatch has been removed, they probably didn't hook up the wiring properly. Does your rear defroster work? If not, look for the plug where the rear hatch wiring is suppose to plug into the body. It may be as simple and just plugging it back in.
Good luck.
The 60 series was the same. Seems with time and junk in the switches they stop working correctly. I have to periodiclally get in the rear hatch and clean the little switch off that runs off the latch mechanism on the rear hatch. My door sensors are sticky now too. It seems they sometimes only let a small amount of power by them. May be enough power to make the open door light operate, but not the actual dome light.
Also fiddling with the the rear hatch handle after it is open will make my rear light work too.
The rear hatch switch is contained inside the upper gate latch assembly.
Well, I found this thread because my rear latch appeared to be the reason my dash door light is not turning off. I removed the rear latch and couldn't find anything wrong and the light remained. After finishing my inspection I forgot to re-open the latch before shutting the rear window and BANG the close latch hit the door. The light finally turned off and now it's working again. Wasn't how I expected to fix it, but it worked!
