Rear ended????
Website
www.grenadaseafaris.com
Hey guys, my wife just got rear ended in our 1995 80 today, nothing to bad, thankfully the 5 series BMW behind her took most of the sting out of the impact that the prat in the shogun behind him caused. The metal fender which has the four holes to mount a tow hitch is bent and needs replacing, the plastic fender end caps might be ok, how much or a job is it to take this off, are there any other bits that usually need replacing in a rear shunt. Anyone got a parts breakdown of the fender they can send me.
Cheers
H
I think that Toyodiy.com has some diagrams.
Make sure your frame is straight. If it's not, then it's going to be a nightmare to get a new bumper on.
The "fender with the 4 holes in it" is actually the last crossmember in the frame of the truck. As Ebag said, get your frame checked out because if that crossmember is tweaked, something else may have shifted. Good luck!
Cross member is welded - it is actually part of the frame. depending on how bad it is tweaked, you may want to have a collision place mess with it, could have pulled your frame geometry off, causing all sorts of other issues.
However, it must also be noted that many aftermarket offroad bumper applications call for :p Cutting the end of the frame off, including the crossmember. Perhaps you could take the insurance settlement and get a nice sturdy bumper.
Or else, you need to have a frame repair shop work on it.
Oh, and welcome to MUD! :flipoff2: You will find plenty of fun people and great advice for when your :princess: daily driver becomes your consuming passion!
What's been said - mind was 'tweaked' a couple of years ago...not badly. Around $800 IIRC.
Thanks for the info guys,
I'm actually in Grenada and I'm not sure they have anything technical like a body shop that can check chassis alignment, things here are a little rough and ready, the hammer is the tool or choice to fix most things, however the upgraded rear bumper may be a good option, i'll have to cost this repair and see how the figures add up. You would laugh if you saw the BMW that got most of the impact behind us, in any normal country this thing would have been junked 15 years ago but here they still drive round in them...... i'll see if i can work out how to upload a photo of it..
Hey, a 15 year old BMW might be a classic. ;)
Anyway, if you're going the rough and ready route then you may want to consider a one-off rear bumper. A simple one would not be hard to do.
If your frame is tweaked, even by a couple MM, it'll make getting a new stock bumper on virtually impossible. If you have no way to straighten it then it'll likely be as much if not more effort getting a OEM bumper on than a custom one off...
I'd love to see photo's, mostly to gloat in the destruction of the BMW of course. :hillbilly:
how900 - my lc has been rearended 3 times! Worst damage was ALWAYS inflicted on the offending vehicle. Worst one was a Mitsubishi Montero Sport, no damage to the cruiser...horrible results on the Montero plastic front. These cruisers have a VERY stout rear bumper system.
Cheers
H
Prat in the shogun? what the.....?
Isn't the Shôgun a type of Mitsu Pajero?
And out of curiosity, how many miles of highways do you have in Grenada?
Yep the shogun is the same a pajero, this little island is only 21 miles x 12 and i think has about only 300 miles of roads, much up and down hills does not do much for the fuel economy.
:eek: I checked out your website, looks like a cool gig. But I gotta tell you, the underwater sculpture park looks CREEPY!
We have something like that here in Las Vegas... created in Lake Mead about 600 feet down by the mob from the 60s till the 90s... Most of the "statues probably have holes in their heads, however...
As a Side Note - I got rear ended in Dallas three times in my Tahoe, due to uneducated drivers and streets that are slick as ice after rain.
:grinpimp:I found the best defense is to keep a raised trailer hitch ball installed even when I am not towing. My ball on the Cruiser is raised 5 inches as the Valley hitch is very low. Will go straight through bumper or radiator if someone hits me, and gives an additional 10 or so inches of buffer space in an accident while distributing the energy of the crash evenly to the main frame rails instead of the rear cross member that is more prone to damage.
I then rely on the shear mass of the cruiser to ensure that the bulk of the crunch is taken by the offending schmuck behind me.:doh:
I've talked with a couple of people who drive for a living (including a guy who drives the Microsoft truck that goes around), and all of them have said Dallas is the worst area for traffic/drivers.
In fact when I talked to the Microsoft truck guy, he was driving another truck because his truck had been rear ended. In Dallas.
