Rear End ID
Bowling Green, KY
Picked this up today, but don’t know what year it’s for. Anybody have tip on how to Id?
The pinion flange patterns change several times from 1963-1985. IIRC, you can find the pattern dimensions & year ranges on Cruiser outfitters site somewhere.
It is a 40 rear, because 45 & 55 have sway bars.
To really nail it down, pull the rear cover & read the build date off the edge of the ring gear.
Looking a little closer, it looks like it has the big u-bolt plates with shock mounts, which starts in 74-75. The manual adjust rear drums end in 1980. So it's prolly 75-80. Spin the pinion & count how many turns to get 1 axle rotation. 4.1 is 75-78, 3.7 is 79-80.
The diff is a rebuilder at this point, needing all new R&P and all bearings. The housing looks good, shafts are probably good once the minor rust is polished off the bearing surfaces.
probably scrap:
R&P
carrier & pinion bearings & seal
pinion flange
axle bearings & seals
brake shoes & cylinders
brake lines & hose
probably salvageable with some cleaning/derusting/polishing
Axle Housing
Axle shafts
diff housing
diff carrier& spiders & side gears
brake backing plates & drums
