rear elocker third question
do I have to lock it in order to take it out? I have the axles and all the bolts out but it seems its hitting something when I try to pull it out?
It's not on a truck, so if I have to lock it, how would I do it?
If it's the rear you need to lock it. just slide it close to the truck and plug it back in. That's what I did.
yep, it's gotta be locked to take the third out. you might need to put the passenger side axle shaft back into the axle and spin it slowly to align the locker mechanism up.
random question - but do you happen to know if the axle housing is different between the locked and unlocked versions (like, does it have a similar notch on the passenger side of the diff housing that is necessary to clear the elocker actuator)?
The housings are not the same. Like you said the locked version has the cut outs for the locker. I have modified a non locked housing to work which is not too hard.
