rear door will not unlock & can't open
Godwin
Resident Herpetologist
Alabama
Having a problem with one of the rear doors in that it is locked and cannot be opened. With the operation of the electric locks the mechanism within the door is actuating but the door is not unlocking. Nor can I manually unlock the door. This presents a dilemma in that the inner panel needs to be pulled to examine the door guts but I'm not sure I can pull the panel without damage with the door closed.
Anyone experienced this before or have any suggestions on how to proceed?
I'd think it would actually be pretty straightfarward to get the panel off. You can fold the seat forward to help out, or even easily remove it with just four bolts.
Now, when that happens to one of the *front* doors, it's a bit more tricky! (But still do-able.)
Curtis
I haven't really dug into this because it's raining. The difficulty I anticipate in pulling the panel is that the lower edge is captured between the door and the edge of the body panel and so cannot be pulled free without incurring damage. I faced something like this on an FJ60 and had to essentially destroy the panel to access the door innards.
Sorry if it's obvious, but when you say that you "can't manually unlock the door", does it mean that you used your key in the keyhole hidden under the rotating "Toyota" chrome emblem near the rear wiper?
I had the same problem just after I purchased the rig and it took me some time to realize that there was a keyhole there! :whoops:
Huh.
The rear of the door near the wheel well or something? I'll have to check it out when the wifey gets home.
Cheers,
Curtis
Guess I wasn't clear enough, driver's side rear door.
Another symptom is that the door lock lever has limited movement. With the electric lock it rolls fully into the lock position but only rolls partially back into the unlock position. In trying to manually move the lock lever back to the unlock position there is some resistance and I'm hesitant to force it.
Ok,
Went out and looked, and I see exactly what you're concerned about.
But: I also took a quick look at the driver's door, and it seems to have the same issue, *and* I know I removed (or at least loosened to where I could get at the lock assembly) that panel without damaging it with the door closed several years ago when I had a problem similar to yours.
Sure seems like you're going to have to carefully dig in there regardless; I can't imagine any other plan of action. :meh:
Keep us posted,
Curtis
I've seen this or something similar. It happens if you have kids and they are fooling with the locks and the inside or outside handle is being held to the open position while the lock is operated (electric or manual). It is usually cleared by releasing the door handle and locking and unlocking the door several times. Since it appears that you have full handle movement when it's locked, try locking door. Then firmly pull on handle several times, giving handle full travel. Now try unlocking door and pulling on (either inside or outside) handle, starting gently and increasing in firmness. It sounds like the mechanism is jammed or hanging up and needs to be persuaded. It could even be dry of lube and all you need is for it to work once to get it open to assess the situation. Maybe even gentle banging on door, just enough to give some vibration while you're working the door handle might be enough. I know it's frustrating, but I've had success myself, with persistence. Good luck and hope you already have it open!!! HTH
I had the same problem with the drivers side front door. Getting the trim off was a real PITA. What i found was on the locking mechanism there was a small spring that had broken. It allowed 2 of the rods that operate the lock to jam together stopping the mechanism from operating.
You nailed it, exactly what happened. I haven't been able to spend any time on this yet and will try the external persuasion (again), but I do want to pull the panel to check the internal mechanisms.
