Rear Dome won't work
Boulder, CO
Just as the title says, my rear dome light does not work. It does work when I switch it to "on" but it does not turn on when the doors are open. The courtesy lights on the doors all work and turn on when the doors are opened. The front dome functions as it should. I tried exercising the plungers and it didn't change anything. I am running George's leds if it makes any difference.
Thanks!
edog's 80,
Does the "Open Door" warning light on the dash come on when you open either rear door or the hatch?
The dash light does have a diode in the circuit, but this does not look to me it should cause a problem with an LED in the same circuit.
According to the FSM if the dash light comes on, that would eliminate all rear wiring except a common wire that goes to the light itself. This wire goes from the drivers side left kick panel thru a six wire connector (IE1) on pin 4. The front interior light also goes thru this connector on pin 3. Both pins 3 & 4 provide a ground from the switches. Just for reference, pin 1 of this connector has no wire.
If you can find this connector and verify it with the front interior light circuit, this may give you a start to finding the problem with the rear.
Thanks!
The ground wire up to the light might have a problem since it works with the switch but not the door switches
I didn't do it .. but a fellow mudder coment about the pin ( door ) switch signal inside of the tail latch ..
I have found these lights, going back to fj-60 days, to be of poor quality. They can be cleaned,grounds traced back and cleaned but in the end I just replaced the poorly built lights. Mike
I don't have any dash indicators of any of the 4 doors ajar.
Thanks
The door ajar indicator (it is on the bottom right side of indicator row) does not light for test when turning on the ignition switch, so it not working with a door open could mean the lamp is burned out. Replacing the lamp would be the easiest way to tell that.
Try one more test for the dash light before moving on. Turn both of the dome lights to the off position, then see if the dash light comes on. This might show some kind of strange LED characteristic that keeps the dash diodes from being forward biased.
If that makes no difference, I would go back to checking the connector at the left kick panel....it is the only separate piece of wiring from the other switches and courtesy lights.
Sorry, I do not have a way to post the wiring diagram at this time.
Good luck
