Rear dome, viper electrical question
Orange County, California
good riddance and hello viper!
But a question on install - I ended up paying a specialist shop to install and the only issue they had was on the rear door and trunk....need to take back to shop next week.
They were saying that the door 'pin outs' weren't functioning so the viper alarm will always thinks the rear door and trunk are closed...
My rear doors never activate the dome lights but I gather this is normal?
Seems that if the rear doors and trunk are all affected there should be common electrical issue here?
Rear doors should activate your dome lights. Switched for rear doors are negative switches, being your dome lights get constant power, but when a rear door is opened, the switch completes the "ground", allowing lamp to light.
May need new rear door switches, they are prone to get gunked up and stop functioning.
Yes, new switches would be ideal. If you have the time, just taking them apart and cleaning them will make "good as new". Just remember they are not 12 volt + switches, they are 12 volt -.
Mine were removed and cleaned very well and still only work intermittently, wiggle the switch and it stays on sometime. I have new switches in a box somewhere in a shop I need to install someday. Very cheap to replace too.
Does Toyota still carry them? I need 1, I cleaned both, 1 works great and 1 like you said- part time.
Had same door switch issues was only able
to get one switch to work 100% the other one is a crap shoot. The rear hatch supposedly has a switch built into the latching mechanism and that never works on mine either. I just figured Toyota never installed a switch but then found some text about it being built into the latching mechanism.
awesome - thanks all - will play around Tomorrow and see if I can come up with something!
One thing that has stopped working since the install is the dash lights illuminating my fuel gauge and battery gauge. Am also suspicious my low fuel gauge no longer lights up. How easy is it to get access to here? I'd rather fix this myself than take it back to the tech and see what else they eff up?! I know they had to open up under the dash for all the wiring.....
My "low fuel" light doesn't come on until it's below empty! I always keep my truck full (or try to) but I wanted to know how far I could go once the low fuel light came on. So, as soon as it came on I pulled into a gas station, and it still had 5 gallons!! I have a feeling this will run forever once it hits "E" and the light comes on..... hope this helps!
