Rear Disc brake problems
Hagerstown MD
My pal in WV has installed a set of Monte Carlo calipers on his late 70's Fj-40. Front end is disc of course. Factory booster and master cylinder. The problem is he has very little rear brake pressure.
I've not seen the setup in person but he tells me he has added a proportioning valve on both lines to try and increase pressure to the rear. He has also swapped the orifices as well. Nothing has helped, additionally another friend is experiencing the same issues.
What are we missing here? I'm still running drums in the rear and don't have the hands on knowledge with this swap. thanks for your input.
Ken
Make sure the system is completely bled, if anything you should have the opposite problem. Is the master cylinder OK? Make sure the bleeder is on top??? Seems odd that both masters would go bad at the same time though. Others have mentioned turning the proportioning valve the wrong way. I would take out the valves and bleed it completely and go from there.
I have fought this batter for a very long time and have "won".
When you say "the rear has very little brake pressure" do you mean braking force or actual braking pressure? If the latter, did your buddy physically measure the pressure at the rear calipers and if so what is it? The former is only an end result and is meaningless in fixing the real problem.
If not get to it. Knowing the pressure at the MC and at each caliper is the only way I know to quantify what is actually happening. Once you know this, then one can work towards a remedy. SSBS makes a kit that I have posted 10,000X.
One doesn't necessarily require the 80-series MC so don't just start throwing $$ & parts at it. Larger MC's only push more fluid to unless one has excessive pedal travel, the larger bore MC ain't going to be a cure-all. And larger bore MC's require more pedal effort as compared to MC's with a smaller bore...pure physics 101. Measure, understand, fix, remedy. Quantifying the pressure is step #1.
With a dual diaphragm booster, the engine running and a panic-stop pedal force, the fronts should have ~1500-2100 psi, the rears (with prop valve adjusted for no pressure drop) ~900-1500. If one can't get these pressures they either have one or more of the following issues in order of likelihood:
-air in system: rebleed
-bad MC: replace/rebuild
-bad booster: replace
-frozen caliper piston(s): rebuild/replace
-pinched, crimped, plugged lines (rare but possible)
This is difficult for me, trying to post a problem and diagnose it not having had it in front of me. I understand that "TJ" (owner) cannot get his rear brakes to clamp down hard enough when stopping. He explained to me his "test" being on a stone/gravel road and that only the front brakes are locking.
I understand the brake bias should give one more front braking as it has more stopping power but at what point should the rear brakes lock? This seems like a poor test frankly. I am thinking there is something not functioning in the master or the proportioning valve has been installed incorrectly, but I can't figure TJ for a poor mechanic. I think were as missing something fairly simple maybe??
Dangle and Jim, thanks
the problem experienced by most with the rear Monte Carlo DB conversion is usually the other way around!
Tell your bud to check the obvious things like stuck caliper piston, pads in wrong, prop-valve in backwards or not adjusted properly. Or like already said remove the prop-valve altogether and see if it helps the bias.
For checking my bias I used a freshly sealed parking lot at a nearby office complex on a Sunday am when no one is around as a 33" mud tire makes a god-awful sound when locked up! This fresh surface shows real well what is locking up when. For me I prefer the rears to lock up right after the fronts do the same. If the rears lock first the truck will swap ends...just like pulling up on the parking/emergency brake of a car. The gravel road method is good too as traction is lower than asphalt.
He can always measure the brake fluid pressure as I suggested here https://forum.ih8mud.com/40-55-series-tech/328776-fj40-brake-problems.html This will isolate the issue to the MC/booster, lines or caliper(s).
F-junker please post the results as you find them i am working on the same issue. just ordered the gauges but haven't gotten them yet.
Dollars to donuts it is the M/C.
That is, assuming that he has bled it right.
You do have the bleeders on the rear calipers at the top don't you?
Mark...
I know this F-junker post started 10 years ago, so guess his problem has not lasted this long, but this could be a good time to explain something never brought up in the original post's back in 2009:
Most guys installing Monte Carlo calipers on the rear are using "used/rebuilt" calipers. These calipers have built-in ratchets that bring the pads up closer to the rotors as the pads wear- - -so that you do not have to pump the brake pedal as pads wear. Problem for rebuilder's is the ratchets are too expensive, so they don't replace them when they rebuild the calipers, i.e. if the ratchets are bad, they merely don't rebuild the calipers, they are discarded/trashed. Since the ratchets wear at different rates, when you buy a set of used/rebuilt calipers, the brakes (and built-in parking brake) have to be adjusted differently from side to side. Before adjusting the parking brake cables though, installer has to actually "ratchet" the pads up to the rotors before hooking up the parking brake cables. If the installer did not ratchet the pads up to the rotors initially, there well be practically no rear braking !!!!!
