Rear diff and spider gears
Colorado
Over the past weekend finally installed the rear disk brake conversion.
Well, I didn't really know how to take out the axle shafts so I just started taking stuff apart and when I rotated the carrier assy the spiders fell out.
Finally got them back together and the axle shafts in but...
My question is: in the picture below, it shows 2 #19 washers. I fished around inside the diff for a long time for the other washer but never found it. Is there supposed to be 2 of these?
edit: This picture is from a 100-series but it is the only break-out I could find. Mine is a 79 FJ40 with 3.73's.
Thanks,
Kirk
They are "dish" shaped to match the surface they mate with. They sometimes do not move from where they are supposed to be (stuck to the gear by the adhesion of the oil) when you pull the pin and the spiders fall out.
There are a very few types of diffs that don't have them, but Cruisers do have them and they should be in place to maintain the correct spacing of the gears.
When doing a DB conversion, you want to make sure that you minimize the end play of the axle shafts moving in and out of the axle housing via different thickness c-clips or by the spacer block that holds the side gears in place (different thicknesses available).
~j.
UpsideDown said:
They are "dish" shaped to match the surface they mate with. They sometimes do not move from where they are supposed to me (stuck to the gear by the adhesion of the oil) when you pull the pin and the spiders fall out.
When doing a DB conversion, you want to make sure that you minimize the end play of the axle shafts moving in and out of the axle housing via different thickness c-clips of by the spacer block that holds the side gears in place (different thicknesses available).
~j.
I checked at the time to see if it was stuck and it wasn't.
I was getting short on time, I know there is a tolerance for the axle shaft end play but I didn't check it. If it is off, is there c-clips with different thicknesses to bring it back into tolerance?
It really bugs me now that I couldn't find the other washer, maybe I'll pull that third and put in one of the spares.
I think it would be easier, less expensive and less time consuming to find the missing washer. It's in there, I promise. Or just put it back together and run it. The washer will be found then...in little pieces of shrapnel attached to the magnetic drain plug. Now get a flashlight, your kneepads and get to work.:)
It should be there... but you should have seen the diff we took out of a Chevy Astro van the other day: there was a missing spider gear :eek: and those washers... long since gone. In fact, the side gears had worn into the carrier on the order of a full 1/2" increase in diameter for the bore they are supposed to ride in.
Oh, and that spider... we found it in the oil passages in about 5 pieces. Oddly enough, the gears were barely messed up; just a few chips here and there (but the whole unit got replaced anyhow).
I once spent 2 days looking for a "missing" spider gear thrust washer. Found it finally in a stupid place. Don't run it until you fix this; this is your 5th warning. :)
