rear diff actuator
Hello
please could someone tell me if I remove the rear diff loc actuator can I still run with out or do I have to fabricate a blanking plate . to put in place of the actuator ????????????
thank you
You can not run without the shaft that holds the collar fork.
So if you remove the actuator you must get a 14mm shaft and drill/tap a hole in it to secure the fork (in the unlocked position) and then secure that shaft to the blanking plate (unlocked position).
Any machine shop could make this I would think but at what cost. Why not just buy a used actuator?
Also if you don't put a plate you will get dirt in around your gears and ruin the axle.
Please post more details surrounding your reasoning and people on the forum usually provide good information.
I've been able to recondition a few actuators quite easily. They get moisture in them and seize up etc.
Repairing actuators has not been difficult from what I have done. Plan on a couple hours cleaning the actuator itself plus an hour to remove/reinstall. If you can't get it working in say 3 hours then it may be time to re-install in unlocked position and find a replacement.
Be careful and read a couple threads before you start. There are specific adjustments that I don't believe are in the FSM but are on certain threads here. If you lose the proper mesh of the worm gear for example you need to follow the thread to reset it. Otherwise it won't work properly. All my info is from several years ago and by memory so I may be forgetting something or inaccurate.
If the above poster has ran without the rod holding the fork then I suppose it is possible, I would not do it personally as I am overly careful. E-Locked rear axles start getting expensive if you damage them.
