Rear control arm bushing question
Urbandale, Iowa
97 LX450
Stock
My Toyota parts guy said bushings are available for the forward bushing and the bushing near the axle is showing as not serviceable .
I told him I thought the rear control arms used the same bushing in both places .
Looking for clarification before I order parts .
He sent me a picture from the parts system and it does not show a part number for the rear bushing. It also does not indicate the front bushing could be used in either place .
Would prefer to just press the old ones out and new ones in.
Thank you
Mark
They are NOT discontinued. Yes, you can press them out/in. I bought mine from Partsouq. Way cheaper than any USA dealer. (not on everything though)
See below thread.
OEM Bushing Kits?
All lower are the same all upper are the same. So order 4 of each. Just replaced those on a rig 2 months ago.
Yep, rear LCAs are the same bushing front and rear hole. Rear UCA's are the same bushing front and rear hole, Panhard is the same bushing left and right hole. So there are three part numbers for the rear, and 10 total bushings.
97 LX450
Stock
His info is likely seeing 100 series, no bushings have to buy the arms, a common mistake on model change years with some of their info. When working on a '97, for most things, we order for a '96, avoids that got ya.
How often can you resuse the bolt and nut when replacing bushings? I hate getting into a job and then have to destroy something and then wait to order the new part .
They look pretty heavy duty like they should be able to be reused but will buy new ones if cutting them off or out is highly probable .
On suspension bolts, always turn the end with the washer, the end with the flange has locking serrations/protrusions. Have never replaced one and had some off many times, but we don't have rust to deal with. Torque to spec and good to go.
Like @Tools R Us said, you can use them many times.
I decided to buy EVERY suspension bolt from Toyota to do my upcoming bushings and all rubber parts swap. It was $125.00 (approx) to get all of them. I figure that's good insurance that I don;t have to order again, and I KNOW I have EVERYTHING if I need it. I can do the job in the middle of the night and not have to worry about having to run and get a part or a bolt.
Negative. 80 series information is exactly that picture from 1991-1997-- there is no issue schematic-wise with MY changes between the 80 and the 100 series
The parts guy just didn't know how to read the schematic correctly. When you click on the PNC for the bushings the Q=4 comes up. He probably did not see it or understand that all 4 bushings are the same.
