Rear bumper wings
So I decided it was time to start building my rear bumper wings. This is going to be a kinda slow process and I’ll try to keep this thread updated as I make progress. Let me know what you guys think.
This was the CAD version. Cardboard aided design.
It’s not sitting perfectly in its final resting place in these pics. The open spot I’ll be filled as soon as I figure out my tire swing out configuration. I know it looks a little droopy in these pics but the bolts aren’t fully tightened. It was 3am when I took this
The main structural components are 3/8 6061 T6 aluminum. The plating is 1/4”. Using a Hobart handler 190 with a spool gun. Those top plate are where the spindle will reside and I will add additional structure there.
I’m curious as to your use of AL.
Not a hater, but steel esp for a wing/spindle/arm seems odd.
Are you going to lathe/CNC some AL spindles to weld into the AL in use - or do you know of some already?
I’m really not a hater....I’ve posted my Miller 350 with a push-pull squirter & my Wooldridge boat is a AL welded tub with a LS3. I get using popcans, 100%.
.....But I‘d love to know if AL spindles are making an appearance, I’ve never heard of them in our sizes.
I used aluminum for the simple fact that it is easy to cut, fit, weld and so on as I do not have torches or a plasma cutter. I plan to use a 1 1/4” bolt on trailer spindle. I am having thoughts now of building an aluminum hinge and not using a spindle at all. Decisions decisions.
Got a little more done. I was struggling with a way to add a steel spindle to the aluminum structure. I had a few ideas that would’ve worked but would have been labor intensive. I decided to use a 1 1/4” galvanized bolt for the “spindle”. The two top nuts are sleeves in an aluminum tube which is then sleeved with a larger aluminum tube that the swingouts will weld to.
All of the holes you see in the outer sleeve were then plug welded and ground somewhat smooth I then drilled holes in the wing for the bolt to pass through ignore the messy work area
Got everything mounted up and started building the swingout arms. The left side will be tire carrier and hi lift and the rights side for a cooler or Jerry cans.
Question for you guys about the toggle latch. I have ordered a 2000lb stainless toggle latch. I plan to attach it to the aluminum with stainless riv nuts. Do I need to attach the latch from the swing arm to the factory cross member or can I just attach the two swingarms together?
Edit: the two arms will rest on plates underneath and there will be a stop behind them. They will not be freely suspended as they are now.
I can't help you with the latch question, but I would add a plate that spans from the top of each wing all the way across to the other to tie them together. It would still be a bolt on affair, but would help prevent any flex. Flex is bad for latches, swing arms, and spindles.
There will be more plating added to the tire carrier and I think it will be much better. It’s definitely getting there
