Rear bumper reflector ? Is it a Snap on or stick on part?
Kansas
I have a scratch in the right rear red bumper reflector and would like to replace it.
I am curios if that's a snap on part or a stick on part with molding tape or adhesive.
If it's just a snap on kind of part I was going to try and order one online and change it out myself. If it's a stick on, I might let my local body shop take care of it.
Anyone ever change out those reflectors.
They are not lit on US Spec LC and LX. Just a reflector.
They look to have been specced in areas that require rear fog lights. 194 bulb.
US are the same as UAE. Blanked bulb hole. Rest is the same as working fog light - mounts, screws etc.
Thank you.
So looking at those pic's in that link, I am gathering that there are two nuts on the back side holding it in.
As long as those nuts are accessible without removing the rear bumper, it should be a pretty simple task to replace one.
According to service manual, rear bumper should be removed. But I think it could be done without that. Try to lay down under the car :)
Is this a fog or a stop light?
Is the wiring already there for USA models or do you have to install wiring if you wanted lights?
Took a peek under the bumper, it doesn't look like USA models have any wiring with the stock reflector. The aftermarket 2016 LC ones look good.
There is no wiring if the bulb hole is blanked. And that`s weird You don`t have rear fog lights... In Europe that`s a must have.
I had to make wiring for it, because in UAE also there`s no need of rear fog light.
Is there such a thing as fog in the UAE? ;)
Sand storm :D In EUR we use also rear fog lights during extreme rainfall on highway. :)
I'm trying something with some inexpensive LED cube lights from Amazon. I used this thread to figure out how to remove the stock reflectors (USA spec LX 570). There are two nuts to loosen and I just reached up from underneath the truck after listening the guards behind the mud flaps. I drilled one small hole above the LED cube light in the plastic of the bumper and even if I put the stock reflectors back in, the holes will be covered. I am using a Quake LED wireless remote and controller to power the cubes.
I have one picture with my Wilco offset hitch gate.
