Rear brake rotors
Front: Time and lots of beers.
Rear: A couple beers and a couple hours.
Pop off wheel.
Remove calipers.
Remove rotor.
Install in reverse order (obviously).
That's all there is to it.
Definitely a DIY.
I just did mine the 1st time a few months back. Other than the one side parking brake sticking to one of them, it took about 60-90 minutes for both. Maybe 30 of it was cussing at and hammering on the old rotor.
watch the "orientation" of the rotors....
maybe it was just me - but I found there is a proper index....(note the peak hole for the parking break adjustment) -
I just slapped them on after bearing job - and got a super odd clicking nose at low speed....
low and behold - "properly" set the rotors and noise all gone...
bf
You may be thinking of the small rubber plugs that fit in the rotor to seal the park brake adjuster hole?
indeed....
not sure if there truly is a index for the rear rotors -
but mine were making an odd odd noise at low speed....clunk - clunk - clunk.....
pulled off the tires - notice the "hole" was set to the parking break - re-aligned and volia -
noise gone....
maye twas just the nuance of my cruiser - but just thought I'd pass along the parable...
bf
No index on my aftermarket ones... other than lining up the hole to be able to adjust the brake if warranted.
