Rear brake help
Mt Juliet, TN
So, I have been doing some work to the 80 and I noticed that the rear brakes were needing replaced. I bought some Wagner Thermo Quiet pads to go on the rear (I know I should have bought Toyota). Anyway, I have pushed the Pistons back as far as they will go and I cannot get the caliper back on the rotor with the new pads installed. I'm fairly confident the Pistons are fully seated. I took the brakes back and the other pads at the store were as thick or thicker. Any thoughts? Something I've over looked. I've replaced the rear brakes before and I don't remember having any trouble. Thanks.
I did that. The bleeder are stuck so that's another issue. A buddy has the caliper compressor tool. I may borrow it to see If I can push it back anymore.
I just did my brakes. Used a caliper compressor tool. It worked perfect though i had to push the piston way in - further than i thought at first
Sent from my iPad
It's less work to crack the lines and bleed the brakes later than bullshitting with trying to push the pistons back in with brake pressure.
There should not be any back preasure,the fluid bleeds very nicely back Into the reservoir. If you think the pistons are seated they most likely are, Its a very positive stop. I have read here several times about this problem, even the 100 series pads are very tight. I dont recommend this for everyone, I have worked with machines my whole life so Its easy for me to do she like this. If you have access to a faceplate of a machine oe something perfectly flat. Get a sheet of 150 grit sabdpaper and with very flat even preasure take about 1/32 off each pad. It wont take long. Check your work..! :) Good Luck..!
Thanks for the replies. I figure out my problem. I had to buy a new caliper for one side because the bleeder was stuck. The new caliper was fully seated. So, apparently the OE calipers are have a rust ring or some other obstruction not allowing them to fully seat.
