Rear brake conversion fj40
Ontario canada
Hello. I have a favor to ask. Could you guys link me the best write up for rear disc brake conversion on a fj40? I search a couple write ups. Thought you guys may know of the best write up... amateur here,your help is greatly appreciated
Welcome to the site. You'll get a better response if you post this question in the 40-55 series tech section. This subject has been beat to death on this website. If you don't get enuff info thru your post, try using the search function. For best result, use the advance search and specifically search the 40 section only. I'm sure there will be plethora of threads on this subject. Also, look in the FAQ's section on top of the 40 series section.
The front disk part of that kit is a retrofit to your drum brake knuckles. Much better off finding a mini truck front axle and pulling everything from it.
Like rugburn said, search... here and on IH8MUD for a better look at your options.
Kodi Lucky Patcher nox
