Rear Axle swap
Howdy! I am looking at picking up a 94 with drums on the rear. How hard is it to swap in a newer axle with discs? Maybe an e-locker? Is it worth it? John
John, the "difficultly" of the swap is a real subjective call, so it's going to be real hard for anyone to say how hard it'll be for you to do the swap.
For me, no problem at all.
Regarding the locker, the axle swap would be the same. You'd have to wire up something to make the locker actually work as the ECU won't support it, unless you swap the ECU.
The other thing that you could consider is that Front Range (I believe) makes a full floater conversion kit for the rear that includes a conversion to disk.
Fred
I am confused because AFIK the 94 came with full floating axle and rear disc brake.
It is an 8 hour job and it did not look that hard. Your problem is going to be manpower, you're going to find out who your friends are because those buggers are heavy. Make sure you swap out your springs and shocks when you do it.
Howdy! Models with ABS were full floaters with disc brakes, but not so for all models. John
