both rear tires off the ground, axle on jackstands, t-case in neutral, front tires chocked so you don't roll away....rotate until the 12mm bolt can be removed, rotate down til you see the topside of the crosspin, with your hand on the pin-side so it doesn't slide thru, tap it gently with a brass hammer...once it starts, it should slide out easily........rotate the center again until the crosspin is visible on the bottomside and clear to come free, then it should slide out...if needed, use a phillips screwdriver in the hold in the crosspin to rotate it gently while you slide it free.
