Rear axle leak!!
Henderson, NV.
Trying to chase down a rear axle leak in my 97 LX. Pulled hub and replaced seals and bearings including the inner axle seal. Put back together still having a weep behind the drum brake pads???? Need ideas! Does the rear spindle have a seal?
Spindle is welded to axle housing on the rear.
Sure your bearings have enough preload? any play there will allow the hub to move around and inner oil seal to lose contact.
There is a spindle seal inside the spindle to seal the axle. There is NOT supposed to be gear oil in the rear wheel bearings on these like what is on a GM.
Then there is a hub seal that seals the wheel bearing hub to the outside of the spindle.
Make sure you pack you bearings with the proper GREASE (I use Lucas RedNTacky #2), then install the bearing in the hub, the seal in the back of the hub (pointing the right direction) install the outside bearing, install the nuts and washers and torque properly.
Then install the axle shafts with the correct seal and tighten the cones and nuts properly.
There should NOT be a weeping type leak. Should not be oil in that location. Only grease.
That's exactly what i did. Still getting a weep behind the pads it appears to be coming where the heat shield is attached to axle?
took it back apart found it full of brake clean!! thanks for the quick replies!!
