In fact, I think a D60 with these shafts is about the best compromise for strength and cost.
even though they are such an inferior design![]()
CTM's are a stupid strong shaft. Jack really does like to use the best materials he possibly can
You happen to have a preinstall pic?
And steve has a tru hi 9" rear axle.
bit of a strength upgrade over a LC axle![]()
So to get back to the original post - now that we have the larger bearing race 3rd's available (e.g. late model FJ80 electric locker diffs), why doesn't someone make a spool with modded bearings for the carrier - that can accept a larger 35 spline axle shaft!
He has a good point. I'd want one, with some 1.25" 35 spline poly axles to go with.
what do those shafts go in?
Did you really use
Jack's shafts and Aisin hubs???
30 spline??
well that's what i was trying to say- make an axle shaft that is uniform in thickness, from one end to the other- the big ass, beefy size that the stock shafts are on the wheel end- the largest end and then make a locker or spool that would accept an axle shaft that diameter
As Mace correctly noted earlier, if you upgrade the carrier to accept 35-spline shafts and also upgrade the shafts you will then have stronger internals residing in a fundamentally weak housing. At some point you've got to quit polishing the turd
.Yes they are 30 spline, with ARP studs and Long’ chromo drive gears nonetheless......
This is not on my truck, nor is it in a vehicle that gets flogged.
The owner wanted lockouts on the rear axle because he dollies his Land Cruiser around, and by turning two dials a quarter-turn, the rear axles are isolated, so he does not have to crawl under the truck and remove the rear drive shaft.
Can you think of better products to have accomplished this same thing in a Land Cruiser rear axle?
Everybody knows this - but those of us who are polishing are just putting off the inevitable as long as possible due to lack of funds or time. My rear seems to be holding up much better since I stopped stomping on the skinny in stupid situations, or took the ego bruising of taking an easier line where possible on occasion.
Ok, I apologize for stating the obvious.
. So far results have included multiple breaks, a blown rotator cuffe, 143 stitches from a shark bite, some interesting head injuries, half rolls (including one in a South Florida yard), and dates with some very interesting women.
Life is good!Wimp![]()
