Edit;So it suppose to let air out but not in? It is suppose to let air out.The breather is easy to check. Just pull it off and blow it, right @2001LC ? Or just preventatively replace?
So the press and bearing tools are just necessary to remove bearing from shaft and not to remove bearing from shaft to get to oil seal on shaft.. Sorry for the dumb question, I am about to dig up my fsm and see what's up... Just wanted a heads up...You just need to remove the axle to get to the seal. There is O ring that should be replaced as well.
The tool is to remove the bearing from the half axle. When you pull the half-axle off the housing, the oil seal stays inside the axle housing: the half axle comes out with the bearing.So the press and bearing tools are just necessary to remove bearing from shaft and not to remove bearing from shaft to get to oil seal on shaft.. Sorry for the dumb question, I am about to dig up my fsm and see what's up... Just wanted a heads up...
| oil seal (rear axle shaft outer) | 90313-62001 |
| rear axle shaft bearing right | 90369-48001 |
| oil seal | 90310-58002 |
| snap ring | 90520-44038 |
| conical washer | 90208-48002 |
| rear axle bearing inner retainer (2 diff?) | 42423-60030 & 42423-60040 |
| o ring | 90301-85004 |
| parking brake shoe | 46540-60050 |
| brake shoe inner | 46550-60060 |
| skid control rotor | 4317-60020 |
| rotors (gear oil is on mine) | 42431-60281 |
| pads (might as well) | 04466-60070 |
What caused your axle play? I have the same issue.Good tip. PVC works. I'll provide some details in a subsequent post.
I have a question though that I need help with. When the axle is all assembled, is there supposed to be about 2-4mm of play between the axle and the hub assembly? Its like the wheel bearing outer race has a little translation inboard and outboard. And the hub will shift back and forth depending on whether you have the axle resting of the diff/spline side vs the wheel stud side. And yes, the c-clip inboard of the outer retainer ring was properly installed.
It's enough to make the outboard dust seal get caught/stuck inside the oil deflector on the backside of the axle flange.
In this last photo, I fought with the outboard dust seal to get it back against the hub, but if I tip the axle so that the wheel studs are on the floor, that seal will get pushed back into the oil deflector.
I can't recall. Sorry.What caused your axle play? I have the same issue.
I rewatched my video (linked above) and there's two things. One is that you can pick that deal out carefully. And then once you put it all together in the axle assembly it sort of goes away.What caused your axle play? I have the same issue.
