Rear adjustable panhard rod
Boston
Website
www.burnmachinefilms.com
Anyone recommendations on where to purchase an adjustable rear lateral control rod for a 94FZJ? I need to get my axel back over about 3 inches.
Even with a 4" lift, you should see the axle offset by maybe 1". Are you running a large lift? Ensure nothing is bent back there.
Most people these days are using a panhard bracket which raises the axle side. Delta Vehicle Systems makes a great one which I have installed in conjunction of an adjustable bar. You can get an adjustable bar from many vendors.
I run the Delta VS unit. No fuss, no muss.
Blackhawk makes one, which is available at Mill Creek Overland.
Blackhawk FJ80 LHD Panhard (trackbar) rod rear
$295.00
  • Brand: Slinky
  • Part Number: SA708512R
  • Qty Available: 25
Blackhawk FJ80 LHD Panhard (trackbar) rod rear is a must when lifting your 80 series more than 2″ . Allows for accurate 4 wheel alignment.
  • OE style bushings for reduced noise and more flex
  • Double locking jam nuts
  • Fine thread adjusting construction for high accurate adjusting, down to 1/16″ of an inch!
  • Zink coating, rust preventative
  • Powder coated Black
Do you have pictures? (Maybe you need to move the axle 1.5" to center rather than 3?) Like everyone else said, using a bracket to get your panhard back to parallel is better than using an adjustable bar. Delta Vehicle systems makes a bolt in bracket and eimkeith makes a weld in bracket, which is cheaper. I used the Delta bracket in my rig and it made a big difference in my handling. I could really feel it.
Yeah I only have about a 2" lift. I'll post a few pics.
