Reaming question.
Reno, NV
Website
forum.ih8mud.com
I'm doing a power steering conversion, and a high Steer kit. I got a TJ Drop pitman arm. After eyeballing things up it looks like it will work fine. It does ned to be modified to an FJ80 TRE taper. A friend of mine has a GM tapered reamer he thinks will work. My question is will it?
Check the actual slope of the taper... I beleive the GM ones are different than the Toyota pitch, I know I have 3 different taper bits, all different slopes.
I was under the impression that Toy and chevy were identical. Although I have no idea about Heep.
Kurt, what reamer do you use for the toy stuff, 1" per foot??
As far as I know GM tapper and toyota tapper are different, at least that is the sorta answer I got from marlin.
I sent my pitmit arm into marlin to have them drill and 1" hole in my arm and have them put a insert in with the proper tapper. They did it for free for me but I bout my high steer arms and rods from them.
My pitmit arm was off a wagoneer, completly flat. Dosn't a TJ have like a 3" drop on it? How tall is this 40? Or do you just have your box mounted weird, like angled up or somthing? My steering angles are perfect, I was excited :) If you go the marlin rout you will need more meat on the end of the pitmit then a TJ has got. I know some full size dodges have a big end on them and a large drop.
I think TJ arms are available with different drops. The one I have looks like a 3" drop.
It's to tall right now. SOA with Old Man Emu springs.
It looks like the TJ taper is steeper than the FJ80 taper, if that is true it should be hurky enough.
I stopped by the machinist that does all my fixtures for work. Turns out he just did a similar project for his son. But he won't do mine unless I buy the correct taper mill.
So the new question is what is the taper on an FJ80 TRE. I made a few measurments with calipers and estimate it to be between 2 and 3 degrees.
Anybody know for sure what the taper is? How critical is it?
