RealTime Help - Front Axle Service
Arkansas
Just finished my Front Axle Service this morning after waiting on a $6 part for a few days. Everything went back together just fine, went for a 2 mile test drive and drove back home with no more clicking birfs. I walked around thinking I was all that and a bag of chips! After cleaning up the garage I was going to check for any play in the bearings. Jacked up the front end and noticed a drip coming from the bottom of the knuckle seal on the DS....!!!!..... WTF??? It is leaking the oh so expensive synthetic gear oil I just put in the Diff. So....... with my ego deflated........ I'm guessing the inner axle seal is leaking. Did I screw it up puttng the axle back in? Was it seated correctly? I'm at a loss. I guess my next step is to order some new seals and parts.......again......... and re-do that whole side.:bang::bang:
Anyone have any suggestions? Any help would be appreciated....
One thing I recall is you have to be somewhat gentle with sliding the axle shaft through the seal into the axle housing, or you can knock the spring out of the seal. I assume if that spring gets knocked free or loose, you won't get a good seal around the axle shaft.
You're sure it's leaking diff oil? The synthetic birf greases have a tendancy to separate and drip a very fine, penetrating oil consistancy type substance that has freaked more than a few guys out.
:beer:
Rookie2
I'm pretty sure it's the gear oil. I didn't drive far enough to effect anything else. I'm thinking the seal got messed up.
You need to pull it apart and look because something with the oil seal is not right.
Post a picture if you can. It does seem strange that you would see pure diff fluid and so soon.
OK Here are two pics. Shoulda done that earlier but... The leak appears to be coming from behind the felt seal on the knuckle at the bolt. Let me know what you think. Thanks.
Looks like your wiper seal cover is on backwards as well.
:doh:, I thought something looked odd there.
Definitely looks like unmolested gear oil. Pull the plug on the diff and save what you can.
It's been a few years since I did mine, but I'm guessing those two indentions on the wiper seal cover plates are suppose to curve around the bolts on the knuckle housing (see them at about 2 oclock and 10 o'clock in your first pic).
Thanks everyone. I had a feeling I was putting the covers on backwards but that is an easy fix compared to going back in for that inner axle seal. I think I know exactly what happened too. When I was setting the seal the spring popped out. I was able to get it back in but I'm betting it came back out when I was sliding the axle through it. Dammit!
The springs came out of both of the inner seals when I was setting them. Is that normal?
The springs came out of both of the inner seals when I was setting them. Is that normal?[/QUOTE said:
Nope, but we've all done it...bummer. When it happens I pull it and replace.
Now that you have to order new parts, pony up for the heavy duty inner axle seals from Marlin. Slee also sells 'em.
A LOT more durable.
Put a glob of grease on the seal and in the U-channel with the spring. Rub it in real good and that will help keep the spring from popping out.
-B-
-B-
Thanks for the tip Beowulf. I'll try it as soon as I get my new parts.
I just ordered some of the Marlin seals.
Just an update..... Finally my 80 is back up and running now! Damn I have missed driving her.
I ordered the Marlin Crawler Inner Seals and was impressed. These seals are much heavier than OEM and are pretty much fail-proof on install. Unlike the OEM, they have an outer lip that, when installed, is flush with the outer lip of the inner axle. When this lip is seated then the seal is set correctly, not at an angle or too shallow or too deep like is possible with the OEM. I just had the DS leaking after the first service a few weeks ago but went ahead and tore it all down again so I could put the Marlin Seals on both sides. I also bought Slees Seal tool and it really helps when setting these seals.
The job was definitely quicker the second time. GOnna put a few miles on her and then check my wheel bearings and re-torque some nuts. In the meantime, after doing this service and swapping the birfs, I no longer have any clicking or other noises...... Oh ...and no leaking diff fluid.
My advice to anyone getting ready to do this is to definitely buy the Marlin Crawler Seals. I hope they last as long (or longer) as the OEM but the confidence of knowing they are set correctly with the install was well worth the few extra dollars. I bought mine direct from Marlin but Slee has them and the seal tool. Prices are same at both but Slees freight charges are cheaper than Marlins.
Thanks for everyones help here! It is truly invaluable.
Glad to see you got it back together. I am putting my brifs back in today after messing up my axle seal last saturday. I also ordered marlin seals and a seal driver, but I got mine from slee. My wife is ready, she hates driving my f-250. I got to get out there and get to work on it, but it is hard to get motivated when it's 12 degrees outside.
Hope all goes well. Make sure you fill the cavity on that seal with grease before driving them in. I used the Mobil 1 Syn Red that I use for the outer hub and wheel bearings on mine. I think that is the trick for keeping that spring in place....that, a rubber mallet and an easy touch.
I understand about the F-250, I've been driving my Power Stroke Excursion since Christmas and glad to get back in the LC. I was up your way working in Missouri last week, when I left it was 1 dergree, windchill -9 degrees. Drove through snow most of the way home. If your doing this outside it wouldn't be any fun. I cheated.....got a warm garage to work in. At least it is warmer today.
Good Luck!
I got mine all back together this evening. It went pretty good. It took a little longer than I expected. I drove it about 20 miles after putting it back together and didn't notice any leaks. I think the popping is gone as well.
