Real Time-VC snap ring removal
Houston, Texas
UPDATE-VC snap ring removal
I have been trying for an hour to remove the snap ring that holds the viscous coupler in place. I am using a good quality sr pliers. I can reach in there and get bite on the ring but when I expand it the ring tightens up on the back side.
I have tried using a dental pick to help lift the snap ring while prying it open but no luck.
I had asked in a different thread if there were any special pliers to make this job easier but had no replies to that particular question. If anyone has a specific pair that has made the job easier, I'd sure appreciate you replying.
Buck
I use Snap-on SRP2 snap-ring pliers. I had to radious-grind the back side of the jaws so that they would clear the splines when opened up to expand the ring.
Yeah that thing is a bitch. The thing I have found is once you try a few times the edges get dull and your pliers will never get a good bite on it again. What I have done is get a helper that can slip a washer or small flatblade under the ring as soon as you open it. From that point on you can use another screwdriver to coax it off. Once its off, get a new one.
You could also drill a small divot in the contact points on you pliers to prevent slipping.
Karl
Thanks for the replies gents. Since I probably can't get a hold of the snapon guy at the moment I'll try the washer trick. I guess it's time to ask the wife out to the garage to assist.
It has been one of those wrenching days. I stripped an oil pump cover phillips head to boot. Good times, good times.
Buck
After another hour of trying, I am admitting defeat. I will take it to a trans. shop in the morning to see if they can get that sorry little bastard off.
I can rebuild the engine but get whipped by a snap ring.
Buck
Just as an update. I frustrated myself for quite a long time on this, without success. I took it to a trans. shop and it took the guy three mintutes. 2 minutes and 55 seconds were spent retriveing the right snap ring pliers. The other 5 seconds were spent pulling the ring out. No charge for the removal.
It's all about the right tool for the job.
Buck
