Real Time PHH Issues
supercarrera
Club Esprit de Four
Santa Clara, CA
Website
www.instagram.com
Okay so I decide to to my PHH before I take my cruiser on a big road trip in a couple days. I knew I shouldn't have tried it. I'm also a glutton for punishment because I got the phh kit with the gates green stripe hose. So after a couple hours of trying to get that hose on, I'm here to say that it's basically impossible to get that gates hose on where the phh was. I just won't go on. I can get it on either the block or the pipe, but not both at the same time. There's just not enough leverege to move that pipe back into place and get the gates hose on the other side. This hose is just not pliable enough.
So I called the local NAPA and of course they don't have any silcone heater hose, so I think what I'm gonna do is just bypass the stupid pipe for now and maybe go back and do it properly at a later time.
What do you guys think?
I bypassed the pipe entirely with Green Stripe. It's much easier to fix in the future and works perfectly well without any issues that I can see.
I just replaced my OEM PHH with the Napa Silcone heater hose. For better access I loosened the transmission dipstick to get some more room to work and also removed the wheel well liners and front DS wheel.
I loosened the upper support for the rigid line going down to the PHH which allowed me to turn it ever so slightly and then I used Syl-Glide (from NAPA) to get the PHH to slide all the way onto the rigid line. After that I aligned the rigid line and the block nipple and it was able to slide the PHH right on. The Syl-Glide was key to an easy install and is not harmful to the material.
I would stay with the OEM design and not by-pass the system, but that's just me. If you need a more pliable hose Napa can usually get parts in next day if you want to give the silicone a try. I think though if you used Syl-Glide and rotate the rigid line slightly the rigidity of the hose shouldn't be that much of an issue. My 2 cents...
Best of luck!
Any dish washing detergent works great for lubing hoses. Dish washing detergent works way better than grease, WD-40, etc. It does create a bond when dry though. I don't know how much sly-glide cost but everyone has dish washing detergent.
I can get the hose on no problem with the dish soap. The problem is that I guess I rotated the pipe too much or something because I just can't get it back into position in a way to get the hose on the block outlet.:mad:
Any tips for tightening the hose clamp where the hose attaches to the block? Looks like you need an extra long screwdriver?
Man I wish I had not started this... It's turning into a two day job and I'm just gonna end up hacking a long hose from the block... I guess that's why they call it the phh... :bang:
I plan on doing the same thing, next time it needs changing that is.
