- Joined
- Oct 22, 2002
- Threads
- 173
- Messages
- 5,457
- Location
- Durango, Colorado
- Website
- www.durangomagazine.com
at some point a quick call to the salvage yard for a used pan may be worth the 5 minutes.
This is a picture on the drain plug where it comes into the pan. As you can see Toyota just put like a nutsert in there for the plug to go into which can end up spinning.
The dipstick tube is in two pieces. The o-ring just seals the two pieces together. You may need to loosen the bolt that holds the upper part to help wiggle the tube apart and pan down. It may take a little work to cut the goop that seals the pan to the case.
Bill
Originally posted by photogod:
Photoman, I see where you get the handle! You have more photos of obscure stuff! Who the h#*l has a shot of the inside of a tranny fluid pan? You crack me up.
my cruiser is in pieces so I just walk over, give something a kick to knock the dust off, and take a picture of it when someone needs help.
Qriginally posted by Grench:
Very nice of you. So... What does your truck need to get you back on the road with it?
Well I'm going to be giving Dan a call in the morning for a new pan. I pulled mine and the nutsert is intact but the bolt just spins. I'm not comfortable with tapping a bigger hole in the pan and by the time I bought all the tools to do it I'm halfway into the cost of a new pan anyway. Thanks for everyone's input and I'll just look at it as I'm doing a more thorough p.m. than I had planned. :denial:
" mode....
Rookie2, The nutsert on the inside is still welded in place. Me and another mud member(Buckru) tried vise grips and several methods to get this bolt out. The bolt just spins inside the nutsert. We tried drilling the bolt out and had to stop short of damaging the pan, it still doesn't want to come out. I figure I'll get it out at another time and learn how to tap a new hole and just keep it as a spare. No doubt I could save some cash but I feel better about going with the new pan at this time. Thanks for your response. Jeff
