Real Time Help requested - Front Rotors...
Prescott Valley, AZ
Ok...I pulled the caliper on the drivers side just now and undid the 6 bolts for the rotor.
Now the rotor is free.....but it obviously cant be removed backwards (towards the diff)...
How do I get the loose rotor OFF to bring it in for resurfacing?
This is a picture showing the rotor is loose....but well......yeah.
Once you remove the drive flange, the lock nut set and star washer, the whole hub/rotor assembly can be pulled off the spindle as a unit. Not sure it you have to remove the hub from the rotor to get it resurfaced.
:beer:
Rookie2
You have to pull the cap off the end, pull the snap ring, pull the drive flange then what rookie2 says. You wish it was that easy, don't ya:)
So I have to pull all the other fun looking stuff to forward of the rotor to remove the rotor as well?
Uhhhhhhhhhh.......:doh:
I see the picture now. You're all wet dude (that mean's you're going about it the wrong way :D). A little more descriptive than before.... you need to remove that grease cap on the end of the drive flange, then the snap ring behind it, then the 6 small nuts on the hub, pop the cone washers (see birf rebuild in FAQ for the method of how to do that), pull off the drive flange, unscrew the lock nut, pull the star washer, and undo the thrust nut. Then the whole thing will pull off.
Also, apparently you don't have the FSM, there's a little bit of a procedure for setting the preload.
:beer:
Rookie2
Yeah, I see that Im in for more than I bargained for...
The rotors still look pretty good, no real grooves...so I think at this time I'll just swap the pads for now.
Im do for a front end job in the not too distant future, so I'll tackle the rotors then.
Did you check to see if you even need to remove them? Most places seem to turn them on the vehicle now. If your unfamiliar with the front end of your LC your probably going to end up causing more problems than the few dollars your trying to save by removing them yourself.
Be sure to remove the greasy fingerprints from the rotor with brake cleaner before putting the new pads on.... And make sure you get the left brake cleaning spray and the right brake cleaning spray for each side or you can mess up the grain of the rotor.
DougM
I wouldn't reccomend re-surfacing in any case. I did that to my OEM's and ended up needing new rotors after six months because the grooves came back real quick.
Kalawang
Anytime the rotor is separated from the hub they should be match marked so that they go back together in the same position. The rotor bolts need to be properly torqued to 47 ft·lbf, if not your asking for peddle pulsation.
