I am replacing my rear rotors and need to know do I remove the caliper as if I am changing the pads to get the rotor off or do I go behind the rotor to the other bolts that hold the WHOLE CALIPER ASSEMBLY to the rotor housing?? I know I may sound confusing but you have the 2 bolts when changing the brake pads and then there is 2 bolts on the back side that holds the other part of the caliper assembly that you do not touch when changing the pads. Which ones do I remove? I am asking because I am having a time trying to take one of the bolts off that you take off when changing the brake pads. PLEASE HELP!!! 1996 L/C. Standing by...
