Real Time Help: PS pulley?
EDWARDS, CO
Help!
I am removing my PS pump in my 92 and cannot remove the pump pulley. It prevents the pump from being removed. The FSM doesnt explain other than "loosen the nut". Well, I got that far. Suggestions? I am stopped.
The shaft is keyed and if memory serves it's tapered. You may have to tap it to get it to pop loose. Rotate it so that the key faces upward so it won't fall out when the pully is removed.
Thanks, guys... I have been tapping and wd-40ing. I thought maybe the woodruff key would need to be pressed as I tried to pull, but so far to no avail... cooling off outside, so, I am taking my 1 :banana: ability inside. I will let you know tomorrow how it does... done for today.:crybaby:
Thanks.
Thanks, Curtis.
OK.... I guess that the difficulty came due to the fact that it was less than 20* in my garage when I was working to remove the pulley. Went after it yesterday... with success. Everything is back together now.I still need to bleed the system out , but need to recharge the battery that died sometime over the last two weeks. I will let you know how it does once the last little hurdle is overcome. Again, thanks for the support.
