Real time help needed....
Winter Park, CO.
I can't get my CDL or rear/front lockers to work. I went to lock the rear so I can repack my rear wheel bearings, and nothing.
I don't think it's the lockers themselves. I exercise them regularly, and the big thing here is that I can't hear the relay clicking. I checked the DIFF fuse in the fuse box and it is fine.
The front and rear lights flash, but the ABS/center diff lights don't even light up or flash.
I searched a bit but didn't find what I was looking for.
I've been doing a bunch of work on my truck lately (PM stuff) and maybe I hit something inadvertently? Stuff I've done is: rebuild starter, PHH, FHH's, throttle body cleaning, u-joints, driveshafts balanced, new battery, slee headlight wiring harness.
Sorry so long, just wanted to give as much info as I could.
Thanks!
EDIT: When I was doing the PHH, there were a couple of connectors in there that my hand was running up against and pushing around, don't know if they have something to do with this...
Update. I got my rears to lock by bridging the sensor in the t-case but
the center still does not lock.
I checked some connections, cleaned them. Still no worky. Then, after I finished my rear wheel bearing repack I went for a test drive. After leaving on the CDL switch, it finally engaged.
If it stops working again, I'll look into the switch. :cheers:
Thanks!
