When I first got my ARB up front I disconnected one of the power feeds to the airbag system behind the glove box. Now that I have read a few threads on this topic I decided to re-engage the airbags. A few minutes ago I removed the ground wire from the battery and re-soldered to the wire I had cut to stop the airbags from going off.
When I restarted the car the engine ran rough, then stalled and the starter kicked on and would not shut off; even after I pulled the keys from the ignition. I had to remove the groung wire from the battery to get the starter to stop. Gave it some thought and tried to re-start; thinking if I drove it a little the engine might smooth out and the starter would behave again. No such luck. Same thing happened; rough running engine, then totally stalling to be followed by unprompted running of the starter until I removed the ground again.
Anyone have any ideas????
