real time help needed with blaster
Dallas, TX
Hey guys. I posted up in Paint and Body but only 8 viewing. So if any of you guys here in tech could help out with a ??? . I keep clogging my media hose. On a pot blaster is the media valve open in the horizontal position or vertical. I have started horizontal and the air comes out alone, then start to turn vertical and it barely starts to etch the paint and then thud. I can hear it clog. The media hose was plumb full of media. What am I doing wrong. Thanks for any help and sorry to post in tech but I just needed alot of eyes.
Brad
Most valves are open when in line with the valve and closed when perpendicular to the valve.
Make sure you are using the right nozzle tip size/psi for the size media you are using.
Also, sift the media to ensure the particles in the pot are all roughly the same size.
Make sure there are no kinks in the hose and your compressor is supplying sufficient CFM for the nozzle tip.
Should run fine then...
All good points!
Newbie mistake #1 Didn't sift prior to first tank. I get about 1 minute of blast time and thud, a bit of amber the size of a small bead clogs the nozzle.
I used the smallest tip because my comp is only rated at 8 scfm at 40 psi. I actually got tired of clogging every 5 seconds and changed to the bigger tip that is supposed to be too big for my compressor, it doesn't clog as much (unless I get that big chunk from newbie mistake number 1).
Now question #2.
With larger ceramic tip on there I get a good flow for about 3 seconds and then media stops coming out, just air. So I close the dead-man valve for a second or two and it starts back up again. Is this because I don't have the right scfm for nozzle?
I actually have two (2) water trap/filters. One at the start of the hose and the pot has one also... neither have any fluid in them so far today.... are they not working?
You have not got enough air pressure.You can increase pressure and step off the distance.Be careful.You can make a boat anchor in a heartbeat.What is the media you are shooting?All the water traps in the world won't help if the media was stored incorrectly and now is only fit to fill a sandbag.It sounds like that may be the case.
Sounds like a compressor, cfm and moisture issue to me.
40 psi is not enough pressure for any pot blaster that I am aware of - what model blaster do you have?
My blaster CFM Requirements @80 PSI: (these specs seem pretty common for a pot blaster)
9 with 3/32 In Nozzle
11 with 7/64 In Nozzle
13 with 1/8 In Nozzle
18 with 9/64 In Nozzle
74fjsemistock- its called amber blast. i bought it at Northern Tool with the pot. the media has been in the bags that it came in. It has been humid and rainy here so maybe it needs to be laid out and dryed.
71FJ40-It's a 60#. working rage it says is 60-110 psi. the 3/32 tip is indicated at 6 cfm @ 110 psi. That may be my problem. I was staying around 60 but I would go up to 80 and sown to 40 to see if anything changed.
Soooo...now the question is do I buy a bigger compressor....I am planning on blasting the frame, axles, and the entire body and paint them myself....
Suggestions, comments, concerns, recommendations...
thanks :beer:
You do need a bigger Kompressor.........sorry:frown:
Ed
You live in Dallas apparently. Personally...I would recommend having someone else do the blasting for you. I am sure there are tons of outfits in Dallas that do this. I know that is not what you asked but if you do a search on the board you'll find, in my opinion, the majority of similar threads leading to the same conclusion. If this is a one time rebuild, gearing up can be expensive. Moreover....blasting a frame makes a huge freaking mess. You'll be pulling media out of crevices you never knew your body had.
I know....you didn't ask.
vtcruiser60- You have a valid point. There is a place called Able's that will blast a frame for $140 according to some local cruisers. That's less than I paid for my pot blaster. Followed by axles and body that would add up. Yes it is messy. Yesterday I wore a full tyvek jump suit. So I stayed pretty media free :)
If anybody else wants to add some recommendations I'm open to them. As I've gone along with this project I've wanted to do more and more myself. Have done nothing like this before. It helps take stress out of my life...
I figure if I'm gonna spend several hundred $$$ on a professional to do it, if I bought all the needed tools at least I would have the tools when all is said and done :p
Any suggestions on brands of compressors to stay clear of? I don't need a professional level but don't want to buy junk either... basicaly just need enough to power paint gun, air tools, blast pot, and not all at once.
thanks
thanks
Can't go wrong with Ingersoll-Rand
The best approach is figure out what power supply you have available (110/220 (single/three phase)), determine what tool consumes the most CFM at what psi, and then choose a compressor based on those criteria
If you have a NorthenTool in your area they usually have IR compressors and will price match - otherwise you can just oder directly from IR locally
See:
Air Compressor Buyer's Guide | Northern Tool + Equipment
71FJ40- would you choose that over any lowes/hd brand? Norhtern Tool has a IR listed as industrial grade 60-gal, 2 cylinder, 3 hp, 230v/single phase (what does that mean vs single stage?) 11.3 cfm@90 psi. for $599.99 with free shipping.
I have 230v in home already but not in garage or shop. Could I just use heavy duty extension cord till I get a plug wired in garage or shop wherever I decide to put compressor, if I decide to do that.
thanks
thanks
It depends - for me, and probably for lots of us who tend try and do it ourselves, you will find that a compressor will be your right arm - you will find yourself turning it on when you walk in the shop and use it all the time.
With a lot of brands they boast a "big tank" - the reality is, it is the compressor that matters (cfm @ ?? psi) if the compressor can not at least match the cfm requirement of the tool you are using, it is irrelevant how "big" the tank is - you will not have enough air to run the tool. Also, I favor compressors that run in an oil bath (such as most of the IR units) they last much longer
Single Phase vs Single Stage - Single phase refers to how may phase the electricity in your building is. Most (all) homes are 220 V Single Phase. Only when you get into commercial properties do you have 3-Phase where each "hot" is an offset phase.
Single stage means that there is one piston in the compressor for compressing air. These units typically have a lower cfm rating than a 2 stage compressor (where a first cylinder compresses the air and then a second cylinder compresses the compressed air from the first cylinder even further. (they run in a serial configuration)
You can use an extension cord from say the dryer outlet to the compressor - just make sure the wire gauge is sufficient for the current draw by the compressor. Depending on the current draw and length of the extension cord, you are probably looking at a 6 or 8 gauge ext cord. (home depot will not have this pre-packaged, you will have to make one)
...my 2 cents worth, bake the media in oven to dry it out, then sift, then place back in pot and try again. If that doesn't work, then you definitely need a new compressor. Another option is to stick a 12" submersible aquarium heater into the pot full of media overnight, stirring the media around it every so often carefully to try and dry it out.
I'll try to dry it today give it another whirl with small compressor at higher psi.
As far a compressor goes, I am sure I would use it, if I had it. That doesn't help with the $600-1000 hit up front. I guess the decision is will I need that much power after this phase of cruiser rebuild is done... blast or angle grind (but can't get into tubed sections) axles and frame.... blast or sand body.... then air for paint gun or use roller method...
Money out is $170 for blast pot, $50 for spray gun. $18 for 100 lbs of media. And about $40 for primer, metal ready and a quart of rustoleum.
If I could get this compressor to work even a little better I would get through the wait for charging... i am starting to think the media had some moisture in it... when it clogged the tip had the finer powdery stuff mixed with some solid pieces... or does that simply mean my compressor didn't have power to push it out...
decisions decisions.....
I am an impatient sort.
If it was me. I would get my blast are prepped and my blast media
stock piled.
Line up the things I want blasted.. frame axels etc.
I would go down on sat morning and rent 180 cfm and or greater
portable
install the matching or slightly less than Nozzle.
Finish it all in one day..
Rental will run on a 180cfm around 80.00 plus diesel.
