Real time help..Need help checking for fuel delivery
Fairfax, VA
So the other day I went to start my truck, it cranked for about ten seconds and did not start. I turned key back on and started cranking, with in 2 seconds it started right up. Well I drive to work, about 2 miles with no issues. I originally thought I was low on gas because my gas light had come on and my truck was sitting on steep driveway. Well I go to leave work and truck wont start. I know its not the EFI relay, I have a spare and have done the upgraded gauge wire. Just for the heck of it I threw in my spare, no start. CEL is on with key to on position. I have a fuel pressure gauge but not sure where to hook it up on my truck. All fuses are good. Going to check for spark as soon as I can get someone here to turn key while Im under hood. Is there another way to check for fuel delivery other that with a fuel pressure gauge? Any help would be greatly appreciated.
Yeah, Im going to check that, if I need a replacement, Im thinking of going with the Supra fuel pump for future mods that Im planning. Does anyone know what year/ model Supra that people are using?
My buddy has a set of noid lights he said I could use. I didnt think spraying starting fluid or gas into intake/throttle body would be a good idea for some reason. Might try that next.
So I got a screw driver and put it in the plug wire coming off of coil and igniter to check for spark, I put srewdriver next to ground and had a friend turn it over. NO SPARK. Is this a good showing that its Coil/Igniter? Any other tests that you guys can think of?
I used an inductive timing light; cord reaches into the cab and fires the light if you are firing while cranking.
My 'CNS' problem was no fuel pressure- see pictures, if you have no fuel pressure and the relays check out, take the time to pull the seats and carpet to get a look at the pump and bracket/wires- the bracket/wires was IIRC $90 from Dan, and the pump I bought (~$300 local) without opening the tank (pump was fine) was a lesson learned.. :doh:
oh well, PM and now I have a working spare. (electrical is non-refundable where I buy local)
