Rattle Can Primer
"the whale's vagina", CA
So I am planning on taking certain areas on my FJ55 project down to bare metal with a wire wheel this weekend. I was looking for advice on what type of primer that comes in a rattle can I can use to cover the bare spots after welding in new metal, etc? I have heard of "self etching primer" in many posts. Is this a good all around primer to use over bare metal? What I am trying to avoid is using the wrong type of primer and causing issues later on when I go to do the bodywork myself OR outsource it to a body shop. I don't want someone to have to take everything back down to bare metal. Any reccomendations on a good general purpose rattle can primer would be appreciated. I am a novice in the bodywork arena so thanks for the help!
Noah
Epoxy or self etching primers work best. Either will give you a stable coat that should then be coated with filler primer sanded, and top coat.
Check with a local auto paint supplier, they have a ton of products and knowhow to get the stuff done right.
Have fun!
Rezarf <><
so an epoxy or self etching primer won't react weirdly to the paint that is already on the vehicle? I plan to sand down the areas that are already painted so they are dulled and so the primer can adhere. So basically the epoxy primer is the best for all around use and won't cause issues with any certain topcoats, etc? I plan to do a very basic paint job, nothing too expensive or fancy. Thanks for the help.
noah
Noah, I'd get a cheap spray gun at harbor freight and use a good quality automotive primer from your auto paint store. You can get a gallon under 25 bucks, gun for fifteen. You'll want a high build catalyzed primer until you get ready to final sand. Might as well do it right, that way there's no problems down the road.
I have had this same question for quite some time. What about using ZeroRust? It has a lot of solids and can be painted on bare metal. Anyone ever use ZR for a base coat?
Noah,
Just make sure that you don't use self etching primer over any bondo because I was told it will eat it away.
Looking forward to seeing some pics in the 55 section!!!!
HTH,
Brian
Thanks Brian, this is the kind of info I was looking for!!
There is some body work that includes bondo on the rig, so I don't to destroy it. In some places it was done well and there is no rust underneath.
Texx, so if I use high build catalyzed primer, would this be the best choice of primer so it does not interact with other paints, bondo, etc. I have a spray gun that came with my compressor, but I don't think it is meant for auto body, will probably get a new one from HF as you mentioned.
Again, looking for a specific primer that won't interact with bondo, or other paints that are on the car. I know the ideal situation would be to take it to bare metal but I am going to try not to have to go that route because of monetary reasons and the fact that a lot of bodywork was done on the rig already. thanks for all the help and opinions. I plan to head to an auto paint place later this week to ask some questions.
Noah
Sherwin Williams makes a rattle can self etching primer that you can use over just about anything (even bondo). Here is the link
http://www.sherwin-automotive.com/products/show_product.cfm?product=7565
Bare metal needs to be covered with either self etching, epoxy, or zero rust. I have used zero rust as a primer with no problems when over coating it with a urethane. The company says that there might be problems with lifting if the overcoat product has been thinned with acetone. All the reducer I used had acetone in it, but it didn't seem to be a problem. I think the secret might be letting the zero rust fully cure before coating. Thin coats of ZR - wait a couple of days. Thick coats - a couple of weeks if it is hot out. Once the bare metal areas are covered with a primer, then shoot the entire car with a 2 part primer surfacer.
Right now I have the hardtop to my 73 painted in just zero rust and it looks pretty good. ZR will fade, but if money is tight that is the route I would go. Get all the body work finished and purchase a gallon of zero rust and 2 gallons of xylene or lacquer thinner. Sand entire truck with 320 grit paper. Zero Rust is about 50% solids and need to be thinned (20%) to spray in an hvlp (1.4 tip). Thin and strain. Spray thin coats and allow about 30 min to flash between coats. Put on at least 4 coats if you are not going to cover with a 2 part surfacer for a while. The nice thing about ZR is it has no isocyanate, can be recoated with just a light scuffing, and comes in colors that can be inter-mixed. It has a satin finish that looks pretty good. Be sure to use the prep step before the ZR. It allows the paint to chemically bond to the metal. I mixed the prep step and put it in a hudson bug sprayer. Spray it on and let dry a day. Put your ZR on.
Tech link to Zero Rust
http://www.zerorust.com/tech.htm
thanks llih! that is some great info. I have used zero rust in the past and love the stuff. Used it on the frame and undercarriage of my fj40 rebuild. Looks as good as the day I applied it. I plan to use zero rust on the frame and underbody of the fj55. I am unsure whether I am going to send the body work and paint out or do myself so for now I just wanted to treat all rust and get things cleaned up. Looks like the link to the sherwin williams is the ticket. This way I can treat the rust areas and clean things up as much as possible and go any direction I want to in the future. I am going to order some cans of this now. Thanks alot for the help, this is exactly what I was looking for!!
Noah
