Raod Manners
I had a question about the ride quality of my 92 LC. I seem to have a lot of sway when I'm on the freeway at about 65-70 mph. Is this normal for that year or do I have something loose or worn out in the suspension. I have had the LC for about three years and the only thing I have done was put new shocks, (top line monroes, got a great deal for the warranty). Could it be that the springs are bad?
Do you still have the factory sway bars attached?
everything is stock on the cruiser. Just the shocks are a year old.
Shocks are probably shot. To put it bluntly saying you have top of the line Monroe's is saying you bought the best of the worst. If you like the stock ride, the OEM tokico shocks for $25 a piece are unbeatable. For better handling, you can get Bilsteins in the $60 per shock range.
Does any one have any advice in helping stable the ride quality of my LC?
Make sure everything is hooked up concerning the sway bars, make sure nothing is broken. Get under the rig and tug on the sway bars, if it gives pretty much any then something is worn or broken or missing.
Some of the OME low-lift springs will do wonders, as would retro-fitting 93+ sway bars or upgrading the shocks. Although I never had any issues with the Monroes that came on my rig, and OME and Monroe work together so the Monroes are comparable to the OME shocks, I'd consider Bilstein or Pro-Comp shocks.
He probably posted that just as you gave him advice! :lol:
Anyway to answer your question is put some good shocks on like cary said these rigs are heavy and cheap shocks wont survive. :bounce2: :bounce: :bounce2:
X2 what Cary said. I had the same problem and I could not figure out what it was. I thought it was a cruiser thing. The while doing my lift kit I noticed 2 things. :doh:
- 2 of my shocks were shot
- my front sway bar bushings were oil soaked and soft
I replaced both and got a much better ride.:cool:
I would start with having someone check out the front end. If everything checks out with the front then end get the steering box checked.
Is the ride quality similar for a 92 LC as with a 95 all things being equal. I drove a 95 and I remember how stable and confident the ride was which is what made me want to buy one, the quality of the ride. However, the price I paid for mine was tough to beat. I am really looking to achieve the same quality of ride. Are the suspension pieces similar through the years?
By the way I agree that monroe shocks are not that great. I feel I should go with stock.
Fluid Monroe's are soft. Way soft. If you are getting a boaty ride, and sway to the breeze, it's the Monroe's.
I use the gas Monroes. The stiffest I could get. It's a single action shock and way cheap but does the job for me. Just make sure you measure your shock length at rest and that your at rest measure is pretty much in the middle of your shock's fully extended length.
Kalawang
