NOTE.. this will ONLY work if you do not have a steering system with a stock rag joint. I have NO idea how this would work with a stock steering system.
short answer is yes, it required modification to three parts..
1. Remove 4 bolts holding the column to the firewall, that bracket will need to have the tack welds cut as it will soon have a new angle
2. cut the welded nuts off the pedal assembly that hold the clamp that goes around the steering column. YOu will need clearance to put these back.
3. Move the clamp assembly that holds the steering column to above the lip, there is room under the instrument cluster. I think it required flipping them backwards or something.
4. Put the screws back into your cut off nuts that have a portion of metal going towards windshield frame
5. weld the now shortened cut section of nuts to the pedal assembly
6. tack weld the now new angle of the dangle 4 bolt bracket on the firewall.
you can also shorten the length of the column at the same time if you would like.
