Raingler products group buy - CLOSED
I think the hangs lower part is dependent on what is in the attic and the material. The clean install is the tightest fit to my understanding because it goes to pillar mounts and buckles that can be added. If you got the hybrid with the mesh and webbing then that should sit tight in the rear roof area.
And not all those pics are representative of a 200 and each type of netting available which is beyond me why they wouldn't post each scenario using each product but whatever. If it was me get the clean install with mesh or hybrid for the attic because it is purpose designed for tie down points that maximizes the net and literally designed for the 200. The easy install is just a net that fits the specs and straps to the hand grabs. Some install required for the clean install but they have videos, instructions and it seems rather simple but I haven't installed one yet.
Any idea how the clean install is installed? There isn’t an installation video (or instructions) on the website.
That video for the 4runner will probably give you a good idea. If you give them a call I'm sure they could answer any of your questions. If messing with your interior and screwing in attachment points is out of your comfort zone they have an EZ install version that just uses the 4 grab handles.
I'm teetering, eyed these for a while but $$. So a GB may be just what I need. I can't tell from my phone, but what's the difference between the 2 behind 2nd row nets? Would have thought the "EZ" would be more expensive, so what am I missing?
  1. Behind Rear 2nd Row Seats Barrier Divider Net (base $218)
  2. EZ Install Behind 2nd Row Seats Rear Barrier Divider Net (base $210)
I think EZ just has 4 hard attachment points and the two middle attachments go around the 3rd row seat headrest or seatbelt strap holder.
While the other ($218 base) one has 8 points of connection and with the hardware kits can be secured even more. they may both be the same net but one comes with more hardware. Raingler is helpful if you want to give them a call.
The install video might be helpful, the first two minutes is the EZinstall, the rest is the 8 points install:
Hey, everyone, I got the 25% off coupon code which is valid Feb 5th - 9th. I am sending it out to everyone as fast at PM's will allow. If anyone wants the code please send me a PM or shoot me an email at "my_username"@yahoo.com.
Sweet. Thanks for organizing this!
While the other ($218 base) one has 8 points of connection <snip>
Thanks, very helpful. Normally I'm all about overkill, but I "Nope'd" right out of the 'really tedious install' halfway through (-: EZ for me.
Anyone use a Raingler roof net on the Prinsu rack? Need to carry luggage on the rack for road an upcoming road trip. What size do i need to get?
I'm in
I’m in - I miss the attic rack that I had in my 80. The 200 could use one also
Which attic do you think you will order? Full, Rear or EZ?
I am leaning towards the EZ model with Hybrid mesh.
IDK but it might be best if you simulate your expected typical load, take some measurements and then order whatever custom size you want.
