Hi,
I'm installing a raingler net with the 8 point mounting. It has three d-rings each side.
has anyone installed one recently?
The middle d ring is attached to the base of the seatbelt retractor on the c-pillar.
I have the panels off, and where I need to make a slot is a lot of air ducting.
Can you advise how you dealt with the slot and the ducting?
Did you run the webbing through the duct and cut a slot through the ducts? Seems like a hack.
