Radius Arm Frame Mount holes
Albuquerque, NM
Been tracking down a click I hear when articulating, stoping, or starting. Finally tracked it down to the drivers side radius arm frame mount. It appears the bolt is able to move around in the hole a little. While trying to determine my ultimate fix for it, I attempted to just tighten down the bolt more to have it press against the frame, but was unable to turn it at all, as it appears it has bottomed out on the threads. This makes me wonder if the PO who put the lift on, caster correction and I believe new bushings, if by chance the new bushing sleeves were not as long as the OEM sleeves, causing the bolt to bottom out before being fully tightened, therefor causing the play in the hole and therefor expansion. Has anyone else experienced this? If so, what did you do to repair it? My two thoughts are to just fill in the expansion with weld and put it all back together with a slightly shorter bolt. Other option is to weld some plate to the side of the frame, drill new holes and mount from there. Im just not sure which way, because both have some negatives, the first is that I am basically trying to weld back to a perfect hole and I am not sure how strong this would be in the long run. The second option would be stronger as I could use 1/4 plate on each side, but I fear I would get some side to side bushing play if I make the walls to thick to where it wont allow the bolt hole area to flex a mm or so to tighten up the clearance there. Any thoughts on this would be appreciated.
I had a similar problem with that bushing moving around a bit and clunking when accelerating or braking quickly. A new OEM bolt cranked down pretty good fixed the problem for me. The original bolt had just a tad of rust in the innermost threads that kept the nut from tightening down all the way.
Basically, if you can get the bolt to clamp tight, the play will go away. It’s the friction of the busing being squished between the two flanges that is supposed to hold it in place, not the bolt acting as a ‘pin’.
This might be the OEM bolt. Does anyone know the specs of the bolt? I found the part online, but cant find the actual dimensions of it. Part number is 9010518006.
I don't know the answer off the top of my head, but I will caution you that these bolts are designed with serrations to hold the bolt in place when torqued. This is one of those items where a real OEM bolt is the wise choice, as you will not find that feature on any hardware/parts store bolt. Not sure if that's where you were going with the question, but I just wanted to put that out there.
I am having the same problem you're describing too. Sort of a clicking when starting and stopping. Its off and on, but I also have MaF brackets so it needs to be looked at.
Update...so a friend of mine and I looked at it more, and we found some gap between the bushing sleeve and the frame walls. Its obvious that the bushings are not OEM because the rubber is still is good condition and I've got 245k on the clock. It appears one of the PO's replaced the bushings and may not have used the right bushing back there or just got one that was not milled exactly correct. In any case, we just added a washer between the sleeve and the frame wall which allowed the bolt to tighten down, get rid of the slack, and bam, all quiet now.
On all of the arm fasteners, front and rear axles, the end with the washer should be turned. The end with the flange has serrations/nubs that are designed to hold it in place, turning them will not result in correct torque. IIRC, 127ft/lb, so more than kinda tight.
