Radio not turning on.
Hi. The first thing to check is the fuse. The fuse panel is down by the driver's right foot. The next thing I'd check is some of the leads coming off of the positive terminal of the battery. One of them might have gotten knocked loose. From there, I'd suggest pulling the stereo out and seeing if something pulled loose there.
If the problem really does turn out to be the stereo and you want to keep it OEM, let me know. I have a fully functioning unit that I pulled out of mine.
pmd you
Forget the OEM stereo. It's a quality unit, but Japanese radios use a different frequency range than we do, so the radio will be all but useless to you. I stuck a cheap Sony head unit in there for the time being. Eventually, I'll replace it with a big double-DIN unit with a backup camera. Some people are all about authenticity, though.
Swapping out the stereo is easy, but there are some things you have to be prepared for ahead of time. You're going to need an adapter to match the new stereo output to the vehicle's wiring. They're easy to find. All Toyotas of that model year can use the same adapter. I got mine on Amazon.
You said you have the CD and tape deck, right? Is your stereo comprised of two stacked components? If so, here's where it can get tricky. There are actually two different stereo connectors in your dash. They're in parallel and they both do the same thing, but the connectors are different. Your current stereo is plugged in to one, but you want the other one for your new head unit. You may need to dig around a little to find it. You'll know you have the right connector when it matches the one on your adapter. Once you find the right connector, the rest of the installation should go by the book.
What else could go wrong? Some models have a factory amplifier located behind the panel over the left wheel well. If you install the new head unit and can't get any sound out of the speakers (or if it cuts in and out like mine did), you're going to have to bypass or replace the factory amplifier with your own. I've got some tips for that too, if it comes to that.
Good luck.
I have tried looking for the other connector, but i cant find it my guess is it might be deep down behind the air vent. How far apart are the two connectors on the harness?
Any tips to look for it?
I found mine back behind the gauge cluster. I don't think you'll find it by tracing wires. I wish I'd taken more pictures.
Forget the OEM stereo. It's a quality unit, but Japanese radios use a different frequency range than we do, so the radio will be all but useless to you...
Would the same be true for a GCC truck/radio? My OEM radio powers up, but none of the channels look familiar. And it has no "AM/FM" switch. I assume this is because (similar to Japan) the GCC trucks also use a different radio frequency?
