radio cutting out
Carpinteria, CA
I just installed a pioneer radio that I got from someone here on mud. It came out of a cruiser so I figured it was plug and play. the install went good until I tried playing music through it. I am only able to get sound out of it at very low volumes. When I turn it up it starts to cut out. I searched the threads and was able to find some info about disconnecting the factory amp. I found the amp behind the glovebox and disconnected the plugs and the radio stopped working alltogether. I pluged them back in and still no luck until I took the key out and then put it back in and started the 80. Now im back to it cutting out at a volume above 3 or 4. Do I need to bypass the amp somehow? Anyway thanks for any and all help,
Paul
I just tried to put a picture on but it says I have to resize the picture and I cant figure that out right now
You're going to love what I'm going to say.
You got a adapter for your radio? So it'll plug into your factory connection? Or, if not. Just dissconnect the line labeled "power antenna". Had this same problem until I went to each wire and figured out the problem. Let me know how it goes!
The power antenna wire shouldn't be an issue, IIRC, it is the coiled blue wire that isn't connected to anything. This radio came out of my rig earlier this week. Paul, check your PM for a couple ideas.
Dan
Thanks for your help Dan. I will start chasing down the rear speaker wires.
With a Pioneer radio, with a shorted speaker or wire, the audio would cut out once, due to thermal protection. To rest the audio, you have to turn off the radio then turn it back on(provided that the audio outputs have cooled down).
If you have not BYPASSED the tha factory amp, then you are sending a high power, high level, input into the factory amp. This would cause the audio sigal to cut out either once or to be intermitten. The factory amp needs to be BYPASSED, not just disconnected.
Use an amp BYPASS harness, or just rewire to BYPASS the factoy amp.
I hope this helps.
tONy
I hope this helps.
tONy
Good info, but in this case, the radio merely uses the power outputs from the amp to power itself, and the bypass is built into the pigtail. I ran this radio with this plug on two different land cruisers without doing anything to the amp. Paul and I isolated the cutting out to either a wire short for a rear speaker or a bad rear speaker, as the volume comes up just fine when running only the fronts, but it cuts out when running all of them or only the rears.
He is out of town for a few days, but will probably update when he gets back.
So I put the stock unit back in and faded to the back and turned up the volume, it worked fine. Then did the same to the front, worked fine as well. This lead me to believe that it is in the harness of the pioneer somewhere. there were lots of cut wires that I thought could be the culprets. I cut and taped those, put the pioneer back in with no change from before(the radio cutting out when it is faded to the back speakers). I faded it back to the front and got it working and while pushing the radio back in it would cut in and out anytime it touched anything. I finally got it back in and working(front speakers only). It seems like maybe the harness might be bad. If so that seems like a cheap and easy fix. I will keep posting the details.
OK,
When you fade it to the back, then try the balance, (audio button, horizontal arrows) and see if you can isolate it to one side. I think that the pioneer unit sends out quit a bit more power than the stock unit, so it may be overloading a worn speaker. If you can isolate it to one side, I would then disconnect the door speaker and see if that cures it. If not, unplug the rear speaker(they are on the same channel) and see if that does it. At the very least, that will tell you if you have a bad speaker or not. One other thing to try would be to unplug the stock sub behind the PS rear cargo panel. It won't work anyway, and may be causing the cutting out. (it didn't in my rig, but the 95 might have a slightly different wiring scheme.
I hope this helps, let me know if I can help out in any other way.
Thanks,
Dan
Thanks Dan,
I will try the rear speaker fade then disconnect them followed by the sub D/C. I will let you know how it fares.
Thanks,
Paul
I really think you connected one too many wires. Not the speakers. Since you're still running through the SAME amp, you're not putting out more. Really try dissconnecting one wire at a time, excluding the hot and the ground wires. I bet you'll find it.
This is a good idea--the harness is plug and play, but there were only 4 days in between the stereo working in my rig, and cutting out in his, so my money is on a speaker. I know very little of audio stuff, but a search on 12 volt said that a bad wire or a bad voice coil in a speaker could cause this.
If you don't find the problem via unplugging the speakers, definitely try disconnecting the wires one by one.
This radio has a built in amp, the stock amp does nothing but provide a pathway for powering the Head unit.
I am truly sorry for the headache this has caused.
Good luck,
Dan
no headache at all Dan,
Im sure that the problem lies in my rig somewhere. The radio plays very well through the front speakers so I am still able to hear music. I will check all of this stuff tomorrow morning after I get off work and keep you all posted.
Thanks,
Paul
