radiator replaced with pics
Dallas, TX
ok... knocked out the radiator replacement this weekend... took me about 4 hours...
I was running for about 135k with the original rad so I decided it was time to freshen up a bit... bought a 93-94 brass radiator via Dan and was ready to go...
First I flushed my system with the older radiator still installed... used the prestone kit but did not install it permanently... just tied it into my water intake pipe and flushed really good according to the prestone instructions...
When everything was clean and clear I started the removal....Basically I followed the instructions I found here on Mud but I wanted to add some pics that may help others... Also the best way to pull the fan clutch and shroud out was to unbolt the fan, then unbolt the shroud, the pull both up and out in the original position.... easy work.... a strap wrench was used to hold the pulley while I unbolted the fan clutch
The toughest part was the 4 bottom radiator bolts which need to be removed from the bottom with a gear wrench (there are 2 on each side)... I have included a pic of the position of these bolts.
Also the hidden middle bolt was a breeze, but I removed my battery box, grille and headlights which made everything much much easier. You can see the back side of the hidden bolt in the 1st pic.. the smooth one with the red wire right behind it...
I basically removed all the hoses connected to the rad, then the 2 side nuts on the side of the L mounting brackets, then the long bottom bolt at the bottom of the bracket, then I removed the 2 bottom radiator bolts that were accessed from the bottom.... After that I just lifted the rad straight out. The new one slipped right in and I bolted it into the bottom L brackets which were left attached to the frame of the truck and then reinstalled the bottom rad nuts..
After all was buttoned up, I did 4 fill and drains with distilled water and after the 4th drain, I filled it up with 50/50 toyota red and distilled..
Doesnt get any better IMO...
1st pic-- remove those 2 nuts on the L bracket and that one on the bottom of the bracket
2nd pic- there are 2 more hidden nuts under the bottom of radiator.. remove them
3rd pic- Original 97 rad vs new 93 brass
additional pics
Pic 1- fan clutch and shroud removed... you can leave the pully and belts on
Pic 2- another shot of the bottom L bracket... remove those 2 side bolts. I also removed that bottom long bolt in the bracket.. the one facing down.. Basically the L bracket has the 2 side nuts and the 1 long bottom facing bolt you see in this pic . I left these brackets in the truck, loosly installing the L bracket back with the long bottom bolt. When you install the new rad just bolt the L bracket into the side of the new rad and bolt back down the L bracket with the long bottom bolt....
Pic 3- here you see again where the under mounted bottom nuts on the radiator are.. remove them.. reinstall them when the new rad is in
here is where I filled the block up.. Is this where most of you fill the block up from? Also filled it up from the radiator cap as well....
also anyone know how to get those funny looking cotter pins out that are used in some of these hoses????
Nice jobs. Looks great. IIRC those cotter pins are OEM one time use. The ones I have removed and replaced, I just dremeled, twisted broke off to replace. ;)
Thanks for the pics. I'll be changing mine out next week as it leaking from the top. It was recommended that I change out the water pump as well while everything is out. I imagine it's fully exposed once the radiator is removed?
Found a used radiator for $175 and new waterpump at advance for $80. The LC's not going to know how to act when I'm done with her.
water pump very easy when you are in there...
my 60 had a few of those hose clamps .... I used a pair of needle nose pliers that had a 90 degree bend in them or small pick with a 90 degree bend. You insert the pick or whatever tool and basically turn the head of the part that looks like a carter pin.... the clamp loosens up and kind of unravels. I don't care for the looks of those clamps but they must be good because i had 20+ year old ones still working fine.
removing the fan clutch and shroud are required to get the radiator out I think.. at a minimum removing them gives you the extra room needed to remove and install the radiator
Nice work !
Yep, the Dremel tool on the old hose clamps are a huge time saver. Just cut the band and pull the clamp off. Don't even bother with that cotter pin. This assumes new hoses are going on and you don't have to worry about damaging the old ones. Which, if you have original clamps on, your hoses are old and need to be replaced anyway !
Agreed, I couldn't get the radiator out without removing the fan/clutch and the shroud. I tried for an hour to shortcut that, but never could figure out a way to get around it. It can be done on other vehicles, but don't know of any way to do it here. Wasted lots of time trying though !
BTW, did you notice there isn't anything on the new rad that says "Toyota" even though, in my case, it came from CDan ? Wonder who the OE supplier is and if it can be had for even less $$. Happy to support CDan though !
did notice there was no Toyota on the new radiator...
Also, do the new hoses come with clamps.. if so what type?
No clamps with new hoses. I used some high quality German clamps that I had an inventory of from working my old 5-series. I find they are better than the run of the mill clamps here as they have non-perforated bands with rounded edges and can be used with a 6mm flexy nut driver that makes install a dream. Go see your local German car independant or the BMW Dealer (tell them you are a BMWCCA member for a 20% discount) and they will fix you up. They aren't expensive. I just keep a whole assortment on hand. Other folks make them, but you'll spend lots of time trying to track them down at a local parts store. They are considered specialty clamps here in the States.
:hhmm: Hmm good info. The toyo shop I like happens to be one of the better BMW shops as well. I used to take my M3 to it.
so do all these hoses need to be replaced? these trucks are over 10 years old now...
Make sure you don't use the el cheapo China hose clamp. For some reason I had one on a radiator hose and it bent enough to loosen up and cause a leak.
What is the reason to replace with the 93-94 radiator and not the 95-97, does it cool any better or is it just a price thing? If so, what's the price of a 93/94 vs 95-97?
Salue
