- Thread starter
- #21
Hi guys,
I'm reprising this thread to ask... Just how difficult is to change a radiator out?
It seems really straightforward to me... and My local Toyota says it will take them 3 hours... I really don't see why I can't do this in 1.5hrs MAX.
I don't mind paying $360 for three hours of pro labor, when it's something I'm not comfortable with.
Am I missing something?
Absent any engine flush I do, isn't the entire replacement process (with new hoses) as simple as:
Am I missing anything? Or any reason why this should take a pro 3 hours, at $120 per hour?
Thanks!
Remove old radiator
- Make sure engine is cold
- Remove radiator cap
- Open petcock and drain coolant
- Remove 6 bolts (3 each side of radiator)
- Unclamp upper and lower hose
- Remove overflow line from radiator
- Lift old radiator out
- Remove old hoses from engine
Install new radiator
- Assemble the two lower hoses and install on the engine outflow
- Install new top hose on the water pump
- Make sure petcock is closed and Insert new radiator
- Hook up upper and lower hoses
- Hookup overflow line to radiator
- Bolt (6) down the new radiator and old cowling
- Fill with coolant - looks like 19.9 qts of Ethylene-glycol - NO ALCOHOL
- Burp system - including heaters
Thanks!
