Radiator question
Dalton GA
67 FJ 40
2f engine
Noticed water leaking from top of radiator coming out of little hole just below the cap after driving. No other leak noted from the radiator. Very newbie so...
Can anybody tell me what it means?
is the hole in the neck? it should have a nipple with a hose attached and used to drain extra coolant on the ground, later rigs the hose goes into an expansion tank.
yes, hole is on the neck. no nipple, no hose.
wondering bc heat gauge not working so not sure if engine overheating.
if the radiator was fully topped off cold, then when it heats up it needs to expand and go somewhere.
