Radiator leak
Chapin, South Carolina
Looks like I have a high leak on the trans line side (driver side) about two inches up. I checked the drain its tight, trans lines aren't leaking and it's definitely antifreeze, is there anything in missing or I can look for before I just order a new radiator? Oh and it looks like it's coming from the front side not motor side.
Thanks
Im in it now for real! I guess I'll change the the trans lines and clutch fan since I'm right there, anything else I might be looking for. Also I lost some trans fluid while pulling how do I go about topping off the trans fluid correctly?
I would replace all the hoses, clamps and belts with OEM. Replace the thermostat and gasket while the cooling system is open.
Transmission fluid is added through the dipstick.
All the hose associated with the cooling system have been replaced in the past two months including the PHH. All clamps and vac. lines that are topside got replaced with silicon hoses also. I replaced the belts about 3 weeks ago. The thermostat and gasket are a good idea! And thanks on the info for the dipstick! And here you go jonheld, wire loom straightened out. Lol
While you are in there; Water pump, front main seal, oil pump gasket.
