I know it has been covered how to remove the radiator with out removing head lights. But i had more time on my hands it looked like the PO had buggered to two hidden nuts that hold the radiator in. So wanted the best access to them. It really isnt bad to remove the grill (5 screws one clip all easy) and the head lights. The only hard part of the head lights is the lower bolt. On the second on i realized that if you remove the front turn signal/running light (depending on how you have it wired) you can get the lower head light bolt out with a extension in 30 seconds, super easy. The front signal comes out with two little screws, also 30 seconds. I didnt even undo any wires or plugs. Just shifted all the lights a inch or so. makes the rad nuts super easy. To me this was worth it to have good access to the nuts. But to each there own. I had a lot of time on my hands and stripped bolts/nuts suck.
