Radiator fin pics....
North GA
I've had past issues with overheating when climbing steep hills, so changed out my fan clutch which has helped. Still, I don't really trust it not to overheat if I start to put a heavy load on it. I know air flow is crucial; my fan shroud is broken and is kinda just hanging there by one bolt. Not to mention all the foam is gone from around the radiator.
So here are the pics....radiator and tranny cooler. Looks bad to me.......thoughts on this playing a major part in my running hot under heavy load?
get a angle pic & straighten those fins out to see if that helps.
it sounds like you are on the right track, you'll get it.
fan shroud is broken? thats one of your big issues right there.... Why not get a good used fan shroud from a parts truck or a new one if still avaliable?
The fins on your radiator and condenser and trans cooler will not stay in pristiine shape...things look normal to me....
