Radiator Drain Plug
Dallas Texas
1983 FJ40
Stock Radiator
Is anyone aware of an aftermarket drain plug that allows you to simply open it up to drain like you find on some of the older cars? Like the old pitcocks that you can spin to drain. I havent done an extensive search for one with a 12MM thread but figured I would ask if anyone had a suggestion. I realize the OEM plug has a small area to allow this without having to pull the entire plug but its messy and sometimes hard to see exactly where the water stream is going. Thanks in advance for any thoughts.
If anyone can you hook you up with that kind of combo, it would be @ToyotaMatt .
