Radiator cracking and failure
Craig, CO
I searched, couldn't find the answer. I have a stock 73 FJ-40, nothing special or extreme about it. Lately it has seen alot of pavement time, DD. About 8 years ago I restore dthis cruiser. At the time we had the original raditor recored. Essentially the radiator gets replaced in this process, the only stock parts left are the tanks the the mounting flanges. The original radiator had lasted all those years without a single problem. Not long after putting the radiator back in it cracked where the tubes enter on both lower corners. I had the same shop repair it. Then it did it again. And again, and last fall it was seeping there again, so I had it repaired again, and now it is seeping again since April. And it is getting worse.
I can't figure out why this keeps breaking in the lower corners. The shop is a good one, I trust his work, but we can't seem to keep this core soldered into the tanks, it just keeps breaking loose at the tubes on the lower corners.
I still have the orginal rubber mounts on the two peices of rod that run down at an angle from the raditor support. The only thing I changed is under the large U spaped support piece. Stock Toyota used heavy cotton belting there for a cushion. But the belting holds moisture and rusts and rots, so I replaced it with some rubber of the same thickness, tightened it down and called it good. The radiator barely moves. 40's don't flex a great deal, I drive carefully, I just can't see where I'm getting more flex or vibrations on the radiator than it did before.
I'm afraid a new radiator may break the same way if I really have a mounting issue, or my old/new radiator is just weak. By the way, I have never had a cooling issue, always runs perfect, so cooling system is good.
Any thoughts, is the rubber a bad idea there, anyone else do this to theirs.
Thanks,
It is entirely possible that the tubes have deteriorated to the point that they can no longer be soldered into a tank successfully.
A new four-core radiator is less than 200.00us. delivered to your door. Radiator.com or something like that.
Stop wasting time and money on this, and move on.
Good luck!
-Steve
Sure the engine is not moving instead of the radiator? Check your front motor mounts, mine was able to pretty much lift the motor. That was on a 74, both mounts gone but looked fine to the eye.
blueflame; I'm not getting any contact of the fan if that is what you are getting at. I'm in the same boat though, my monts look fine but I wouldn't swear they are perfect. Or are you saying the jumpy motor could be causing excess vibrations or torque on the front frame rails.
armourguard; Cap is good, replaced it a few times through the years, 13 psi I believe is the correct pressure, off the top of my head. System cools fine, and works correctly, just keeps seeping out of the radiator where it cracks it.
Poser, I can't see where an entirely new core could deteriorate that badly in 8 years time and 58,000 miles that it won't soilder back together. I'm in a good climate, not very hot, sometimes pretty cold for the lower 48 states. My cooling system is not overly abused. Probably needs a good flush though. I'm not real regular on that.
I completely understand your faith in your radiator shops ability and craftsmanship. What I am saying is that at some point, it did not get cleaned well enough and soldered together well enough to stand up, weather it was when it was initially put together, or over the many times that you have tried to have it repaired. It is significantly harder to get the tubes to seal in the tanks the next time around, compared to the initial install.
Further-
Everything has been made thinner and lighter over the years. You will not find new radiator core sections that are as thick and easy to work with today for an automotive application, as you would have seen twenty years ago.
Just go new, and don't look back. I installed a CCOT 4 core unit a few years back and it seems to be doing just fine. I also believe that had my water pump shaft not failed, sending my four blade metal fan through the radiator core and bottom tank, that the radiator I had built back in 1989 would still be in the truck....
From your explanation, I think that it it is entirely possible that your radiator shop was supplied with the wrong core for your tanks, and that they had to 'force' the tanks out of their natural shape, even just somewhat slightly, to conform to the core.
The stress in the deformed tanks remains, and solder, which is only designed to seal, not to bind, is simply insufficient for the task.
IF this is the case, your problem will not cease until you buy a new radiator.
I tried the company the other guys referenced on this thread a few times last year. Two of the three radiators I ordered were damaged upon delivery. THe third failed within 6 months.
I went back to my original source for the radiators I sell.:)
Good luck.
Mark A.
Thanks everyone, Mark, Steve, good thoughts, that's the info I needed. Guess I'll find a new radiator, hate to give up the half original, always fit so well. But I'm tired of getting it fixed at 50 bucks a pop, and it leaves me with a very weak link all the time.
Again thanks, Graham
Sounds like you have made the decision to replace the radiator.
As and FYI what you describe is exactly what I would expect from a cold solder joint or a contiminated soldering surface. I suspect the reason it shows up in the corners first has more to do with expansion and contraction than flex or vibration. The channels along the sides may be acting as heat sinks which resist heating and speed cooling compared to the center.
As Poser mentioned if the solder joint was contaminated during the initial assembly it would be difficult to correct without starting over.
By way of credentials, my "day job" is all about soldering and trouble shooting soldering processes.;)
So nobobdy beleives the rubber under the radiator support is to blame for this, because I think it was a good upgrade myself.
Thanks everyone, G.
I know this is very late reply, but I had this problem when the bib was contacting the radiator bracket, due to a mishap with a tree. This was flexing the bracket, flexing the radiator, and causing the failures in the corners. I bent the bib back and all is well.
My cruiser is fairly un molested. I don't have any body damage on the front end at all. The bib does not contact the radiator supports. I had thought of that and looked for it, but it never really showed to be an issue.
I have since replaced the radiator with a new aftermarket unit, so far, so good. Now if I could only keep the rear heater core from cracking and leaking every year and half or so, I would be leak free for once. Oh well, may have to upgrade the rear heater some day.
Thanks for the reply though.
